Yamaha oil filters vs. Fram oil filters
Guest Mackinawman
Just bought and installed a Fram oil filter on the RSV.
Half the price of the Yamaha filter.
Pros and Cons please - Thanks!
Wayne, a lot of us have problems with the quality of Fram filters. i personally would not use them. There are much better ones out there and I am sure others will jump in also Do a search and I am sure you will find out much more that you needed to know.
I gave up on both years ago after one of the folks cut them both in
half .. VERY THIN !!!
I now use Super Tech ST7317 from Wally World ... Far Superior to both of
them and at $2.50 a pop, not a bad price ...
Please, I beg you, take the Fram filter off immediately and put something else on. Don't even wait for the next oil change. Fram makes the worst filters on the market. Cardboard fibers have been known to come out of the filter element and ruin engines. Y's own filters are a close second to the worst. Here's a list of more than 50 filters that are better. The Supertech ST7317 is around $2.50 from Mallwart and is about the best deal around.
http://www.venturerider.org/forum/showthread.php?t=523
Fram is JUNK
I ues a AMSOIL EaOM103 for my Vstar 1100 and it has a check valve to keep the oil up in the top end of the motor so it dont let it drain back
I'm using the best oil filter on the market.
Purolater Pure One PL14610. Get em at Advanced Auto for 6 bux.
"This is how an oil filter should be made. The anti-drainback valve is double the thickness of any other here, and obviously seals very well. The media is the best available, and there's a lot of it. The bypass valve is made from a laser-cut piece of stainless steel, and just can't bind or jam."
I believe that all the Honda, Suzuki, and Yamaha filters are made by Denso and are all the same. I'll just keep using the Pure One filters.
http://www.venturerider.org/forum/showthread.php?t=15162&highlight=purolator
I never had a problem personally with Fram filters. Ran em on my Roadstar until I read up on the Pure One filters.
Not going to get into a debate about oil or filters.
I used to work for Midwest Filters and we made them all.
Ford,GM,Toyota,JD,HD, you name the filter we made them.
After saying that I use Supertech in all my vehicles.
I would never get between a person and there beliefs, so if you think something else is the messiah of filters or oil you go 4 it.............Ron
Guest kozman01
I'm not a messiah on anything, but I've cut open my share of oil filters. Purolator Pure One are great filters for only 6 bucks. I have always used that filter and I do an oil analysis on EVERY oil change on my Venture and 06 Acura TSX(also uses the Purolator Pure One) and my particle counts are always very, very low. Just my two cents.
The Yamaha Filter is a complete and end-to-end connected ring of filter paper. The Fram (according to Yamaha) is an incomplete ring, and thus prone to allowing particles through that would be caught in the Yamaha spec filter.
There where quite a few different brands of filters that ran through the line after FRAM same filter just different brand name.
When we ran say Ford filters after there run we ran FoMoCo,Walmart,Sears,KMart for instance, they where the same filter but different label.Cost for us was less and we could off set the setup cost to Ford who ordered the filters and we never had to worry about holding inventory.
The brand name of a label really only means something to the designer and the person willing to pay $20.00 for a name.
I change my oil & filter every 3000 miles or before a long trip and after I return or even during the trip if it will be more then 3000 miles during the trip.
In the general scheme of things all I really need to know is if the filter will do its job and I change the oil on a regular interval.
That is more important then what brand of oil or filter we use.
I tended to run vehicles til they died from exhaustion then would fix them up and run it some more.
Most people keep a vehicle 4 years and trade it in.
This 02 I will have 2 more years then will buy a 08 slightly used.
I hope this helps you out Mackinawman and as you see there are wide and varied opinions on the subject.
If you check here http://www.venturerider.org/forum/showthread.php?t=1849 Rosebud did a nice job of cross referencing.
Or you could spend the big bucks and get a YAMAHA filter............Ron
Guest Mackinawman
Thank you all for the great feedback!
First thing in the spring the Fram is coming off. Should have asked before I bought it. Duh!
I have the Rivco adapter for my 1st Gen and use the Mobile 1 M-105. From everything I've read it's one of the best. I guess I look at oil and filters the way I look at tires, that's not the place to pinch pennies. Get the best you can.
Guest KitCarson
Oil is oil.......filters are filters.........use any kind you want, change them both at 3000 miles......do not make your brain hurt:stirthepot::stirthepot::stirthepot::stirthepot:bet this starts a war!!! :sign20:
A BIKE IS A BIKE!! JUST GET ON AND RIDE!! LOL
ithink in the end you are right.i put 150,00 miles on my 89 escort and used walmart oil and filters from day one.gave it to my niece and she drove it another 25,000.never an engine problem and never used oil.changed oil and filter every 2000mi.good oil and filters in my scoots just buys me piece of mind.bill :)
I don't have much support for this comment, I don't know if it's really true or not, but FWIW - I have more than once heard parts counter guys say that the worst oil available today is still better than the best oil we had available 40 years ago during the muscle car era.
no doubt about that.i remember when the very best oil you could buy was from pennsylvania.it was parafin base oil.all other oil was asphalt base.no imported oil back then.penzoil was about the best available because it was in a pretty yellow can.than royal triton made their oil purple and it was so pretty it just had to be the best you could buy.sunoco was the only gas to use if you wanted to win any drag races.fram and purolator were the top oil filters.them was the good old days before big business ruined dragracing.shot the little guys like me right off the track.just so glad i have those memories to dwell on.what an era that was.i remember the day the dodge chargers came to town with their altered wheelbase supercharged funny cars.to put on an exibition run.yep them was the days.:clap2::clap2::)
How does a low particle count mean the filter is good. Filters are supposed to trap particles ,, aren't they?
Just asking!
Bill P
