Showing results for tags 'clutch slipping'.
WHEN YOU ROLL ON THE THROTTLE OF YOUR FIRST GEN. MKI (1983 TO 1985) DOES THE CLUTCH SLIP? WHEN YOU "BRISKLY" GO FROM FIRST TO SECOND GEAR DOES YOUR CLUTCH SLIP? DO YOU RIDE 2 UP OFTEN? ARE YOU TRYING TO PULL A TRAILER AND IS YOUR CLUTCH SLIPPING? ARE YOU THINKING ABOUT PAYING $300.00 PLUS THE INSTALL FOR A BARNETT CLUTCH,WELL THINK AGAIN! THE STOCK YAMAHA CLUTCH IS A HIGH QUALITY UNIT AND WILL LAST OVER 100,000 MILES. THE PROBLEM IS NOT YOUR CLUTCH, IT'S THE 6 CLUTCH COMPRESSION SPRINGS THAT HAVE FAILED. SO HERE'S THEFIX! INSTALL AN AFTERMARKET, THICKER SET OF CLUTCH COMPRESSION SPRINGS, AND FULL CLUTCH DISC AND NEVER WORRY ABOUT THAT FIRST GEN. MKI CLUTCH AGAIN! THE 6 HEAVY DUTY CLUTCH COMPRESSION SPRINGSPUT 25% MORE CLAMPING FORCE ON THE CLUTCH DISCS THAN THE STOCK FIRST GEN. MKI CLUTCH SPRINGS. HERE'S MY DEAL, YOU GET A SET OF BRAND NEW HEAVY DUTY CLUTCH COMPRESSION SPRINGS, (NAME BRAND) A NEW FULL SIZE CLUTCH DISC TO REPLACE THE HALF DISC, AND A BRAND NEW, GENUINE YAMAHA REPLACEMENT CLUTCH COVER GASKET, EVERYTHING YOU NEED TO DO THIS INSTALL FOR $85.00 INCLUDING SHIPPING IN THE USA!!! OUT OF THE COUNTRY BUYERS WILL PAY ACTUAL SHIPPING COSTS ONLY! IF YOU HAVE SOME MILES ON YOUR CURRENT SET OF FRICTION DISCS, OR THEY ARE OVER 30 YEARS OLD, I WILL THROW IN THE REMAINING 7 GENUINE YAMAHA FRICTION DISCS or the 7 STEEL CLUTCH PLATES FOR $105.00 A SET EACH, MAKING THIS UPGRADE BASICALLY, A BRAND NEW, BETTER THAN STOCK CLUTCH! I WILL INCLUDE COMPLETE WRITTEN INSTRUCTIONS, AND I HAVE A PICTURE FILE THAT CAN BE DOWNLOADED! WHAT A DEAL! THIS UPGRADE CAN BE DONE IN A FEW HOURS, DOESN'T REQUIRE THE REMOVAL OF THE CLUTCH BASKET, CAN BE DONE WITH A 10MM AND 12MM WRENCH AN ALLEN WRENCH AND A PAIR OF SIDE CUTTERS AND NEEDLE NOSED PLIERS AND YOU WON'T LOOSE A BIT OF ENGINE OIL. YOU CAN CONTACT ME AT: skydoc17@gmail.com IF YOU HAVE ANY QUESTIONS. THANKS FOR VIEWING MY AD, EARL.
- clutch slip
- mki clutch slipping
(and 2 more)
I just got a 99RSV Bought it "kind of" running Tuesday, shows 10,800 miles. Back story includes it sitting "under" a carport in Arizona for the last 5 years. After finding several issues in the carbs, she's back together and I fired it up this morning. Put on 160 miles today and all is good BUT the clutch is slipping, bad, wasn't sure it would make it up the last hill to my house, had to go down to 3rd with very careful throttle use to do it. So: Has anyone tried the caltric clutch plate and gasket kit? http://www.ebay.com/itm/291355972200 I will also use the EBC heavy diphragm spring and probably get rid of the half plate and wire. Which means reusing one clutch friction plate. Will scuff sand the steels before reassembly. Thanks for the great forum! I have found more than my money's worth of useful info so far with plenty more to come. I plan to put about 4,000 miles on the bike this summer. Sunrise this morning, yeah I wanted to ride it bad. It will never be showroom again but she's cleaning up pretty good.
- 10 replies
- clutch slipping
- friction plate
(and 1 more)
