Showing results for tags '12v outlet aux audio mod'.
Found 1 result
  1. Hey guys- This may have been done. Did a search and didn't see it... so here goes: I wanted an extra 12v outlet on the right of the fairing, because sometimes I want to charge my phone as well as have the GPS (who has a grumpy battery) running.(new GPS has a special cord, so I can't use my USB double charger anymore.) I also removed the casette deck, and made a little storage area. I had a wire coming out of there, and then out from under the fairing... but when I didn't have something plugged in, I didn't like the cable hanging out. So I tried adding a new, easy to change aux plug in case this one fails over time. Started with a black rubber coupling from radioshack, but it didn't work. Use the gold one you see in the pics. it's worth the extra 3 bucks. This was just an experiment, but seems to have worked perfectly and gave me just what I wanted. First, drilled a hole in my beautiful fairing. I drilled too small, and slowly filed the hole more until it had a nice snug fit. However, the final solution would probably work with a hole slightly larger because I came up with a good solution for holding the plug in and waterproofing the opening. I drilled right behind the speaker, so that the plug is facing down when installed. This should eliminate almost all chances of water getting in there: http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7390.jpg Then, I put an e-clip around the coupler with a neoprene washer, and put it in the hole from the bottom. If you look close in this pic, you can see both parts. http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7403.jpg Next, in the inside, I used another washer, and then a bushing to help me get the e-clip on nice and tight. I was using the grooves in the knurled texture of the coupling as a groove for the clips. I think these were 1/2 inch e-clips... but I brought the coupler in and just figured it out in the hardware store. They have to fit tight. The bushing helped make it easier to put the inside e-clip on with pliers because I had space between the fairing wall and the clip's groove. http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7399.jpg Next, I just used a small patch cord to plug in to the aux input of the bike to the coupler. DONE!!!! http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7404.jpg Here's how it looks from the bottom of the bike. I really like it because you can't see it unless you kind of squat down and look up. Very inconspicuous. http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7400.jpg Since I was there, I looked at this 12v outlet I got from a marine supply warehouse in town. (So I'm assuming it's "weather friendly"). I wanted to add it to the lower right fairing and just tap in to the other 12v outlet. I used a 1" Flat wood bit (the flat kind with a point, if you know what I mean) to drill a hole- but that's slightly too large since I didn't have any washers. Not a problem- it still fits, but I want to add washers to "clean up" the look and keep water from seeping in around the edges. Didn't take many pics at this point, because I just kind of did it on a whim. Here's the outlet installed on the inside: http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7406.jpg And here's the front side, with the plug for aux audio supplying all the necessary "Music to mod your bike to" tunes: http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7409.jpg I'm really happy with how it turned out. I didn't have a perfect size bit for the lighter outlet, but it's close enough, I can't see light around the lighter with the front of the fairing off. But I plan on installing a washer on both sides (those neoprene big washers) to seal it up and reduce jiggle. It looks great as it is, though!!! Here's a more distant shot so you can see better where the mounts fall in the fairing. http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7410.jpg Oh- and here she is with an f4 windshield with vent installed: http://i250.photobucket.com/albums/gg249/screamstone/CA2008/bike%20mods/th_IMG_7418.jpg This was my first pictoral little tutorial... hope I did it right!! I don't know how to lightbox the images... sorry about the new windows opening!
