Ok,ok.. It's probably a stupid question, but as I have said before, I have electrical knowledge and not much mechanical, so I would rather ask a dumb question than risk messing something up. I just went thru the seafoam proceedure and do not wish to start the bike up until I put a new filter in it, but after locating that filter I see that I cannot even get a finger in there, let alone tools to get it removed/replaced. The metal band around the current filter seems to be bolted from underneath and the fuel line (towards the engine) looks like it would be lost, or at least very difficult to retrieve if it slips down into the abyss. Can someone please give me an easy step-by-step fuel filter removal proceedure? Is removing this a delicate surgery with long needle nose pliers and lots of swear words part of the deal? Thanks Muchly... Johnnie
Turn off fuel at valve on right side of bike
Remove left side cover & unbolt fuel pump mount
Remove fuel pump & let dangle over the side
Filter mounting bracket is held in place by one screw above inlet hose
Remove screw & inlet hose from filter
You can now pull the filter mount out for filter change.
Install in reverse order.:080402gudl_prv:
while you have the filter off.
use a good flashlight and really inspect the fuel line running back to the petcock.
mine was almost "squeezed shut", by the bendable support clip, in the center section of the fuel line.
just jt
See, I never would have thought of removing the fuel pump. Thanks again! And I will check that fuel line too.
Johnnie
(Keizer, Oregon)
Or you can go to O'Reilly's auto parts and get the clear racing filter ("bout the size of your thumb). There's room for it in front of the battery.
Now why would he want to put a fuel filter, at the steering neck????? There are no fuel lines there....
