Freebird Posted August 29, 2006 #1 Posted August 29, 2006 Mic-Mutes Installation Mic-Mutes is a product designed and marketed by VentureRider member Bill Morphy. This is a fantastic product and one of the best things I have done to my audio system. The one thing I have always disliked about the intercom system on the RSV is the fact that the mic is always on. In order to communicate with my wife, I need to set the IC volume on at LEAST 14 and that is borderline if you are in a noisy area or running at freeway speeds. Any higher though and the wind noise picked up by the mics is really a bother, not to mention that it severely degrades the music quality. Mic-Mutes solves this problem with a totally integrated system which allows you to toggle the mics on and off by using the push to talk buttons for the CB radio. Operation is very simple...just press and release either button (front or rear) to turn both mics on. To turn them off, just press and release either button again. To use the CB...simply toggle the mics on and then press to talk as you normally would. After using this system, I can honestly say that no RSV should be without it. This is a quality product at a fair price and not difficult to install. The hardest part of the installation is stripping the bike down and getting it ready. This is not difficult but a bit time consuming. You will need to split the fairing, remove the seat, remove the gas tank. The Mic-Mutes comes with a small black module that will need to be placed either under the seat or near the battery area. I placed the module just behind the battery. Look carefully and you'll see it in this picture. http://www.venturerider.org/micmute/pic10.jpg The wiring is pretty simple and mostly plug and play. Under the rear seat, on the left side, you will see a 5 pin din connector. Simply unplug the connector and plug one of the included headset adapters in line with the separated plugs. http://www.venturerider.org/micmute/pic1.jpg Now you will do the same thing with the 5 pin din connector inside the fairing. There are 5 of these connectors inside the fairing, you want the one that is marked with the red tape. Simply unplug that connector and plug the other headset adapter in line as you did on the rear. http://www.venturerider.org/micmute/pic2.jpg Integrated into each headset adapter, you will see the telephone type jacks. There are two control module cables that come out of the black module. You will want to run the long one to the front jack and the short one to the rear jack. The best way to run the cable is along with the other wiring going to the front of the bike. As you can see in the following picture, there is a guard over the top of the wire way that you will want to remove to run the wires to the front. http://www.venturerider.org/micmute/pic3.jpg After the wires are run, just plug them into the jacks. http://www.venturerider.org/micmute/pic4.jpg http://www.venturerider.org/micmute/pic5.jpg Now that the headset adapters are installed and connected to the control cable, we have to connect the module to the passengers audio controller. This too is done under the rear seat. On the right side of the bike, near the trunk, is a 6-pin connector. Mic-Mutes supplies a tap slice connector to make an easy splice to this wire but I prefer soldered connections. Whichever way you decide to do it, you want to splice the yellow wire from the Mic-Mutes module to the green wire of the bikes connector. http://www.venturerider.org/micmute/pic6.jpg The next picture shows my connection soldered. Then just tape it up well and this part is done. http://www.venturerider.org/micmute/pic7.jpg The last step is to connect the power to the module. Most of you know that there is an unused power circuit under the seats of these bikes. It is located on the left side of the battery on the left side of the bike. It is simply two wires with a white connector which is not connected to anything. This is the easiest place to connect the power to the Mic-Mutes module. Again, Mic-Mutes supplies tap splice connectors for this splice but I chose to just cut the factory white connector off and use butt splices to connect the power. Very simple. http://www.venturerider.org/micmute/pic8.jpg That's it folks. Just put everything back together and test. Mine worked perfectly and does exactly what it is advertised to do. Try it, you will like it. For more information or to order, check it out at http://mic-mutes.com/
