RevJonG Posted September 6, 2013 #1 Posted September 6, 2013 I have ordered a Custom Dynamics TF115ARC. I need to tie into the brake light, running light, and turn signal wires. What is the easiest way to do that? Is there a "plug and play harness" available? If not where is the best place and best method to gain access to those wires? Thank You! RevJonG
XV1100SE Posted September 6, 2013 #2 Posted September 6, 2013 See the thread I did on installing the Custom Dynamics run/turn/brake lights - http://venturerider.org/forum/showthread.php?t=77681 Another option for tying in under the seat is to use the harness available from M61A1MECH. See his ad in classified.
etcswjoe Posted September 6, 2013 #3 Posted September 6, 2013 I used M16A1MECH's harness and it was very easy and hasa lasted almost two years now.
Barrycuda Posted September 6, 2013 #4 Posted September 6, 2013 I used M16A1MECH's harness and it was very easy and hasa lasted almost two years now.
billmac Posted September 6, 2013 #5 Posted September 6, 2013 nothing as easy unless you like working in a small place.
Brake Pad Posted September 6, 2013 #6 Posted September 6, 2013 I put mine right behind the brake like wiring. two males pins into one female receiver, just crimped the wiring together.
ToyOdie Posted September 6, 2013 #7 Posted September 6, 2013 I installed mine under the seat. The plug that goes through the back of the seat pan and through the fender has all the wires you need. I spliced in on the frame side (not the fender side) of the plug. That way I could remove the fender with out cutting back into it. I remove the fender when pulling the rear tire. The installation is very simple. Just make sure you check the color code of the wires. I attached the load eq under the seat too. I just zip tied it to the seat rail and attached the control unit to the seat pan by drilling 4 small holes to run zip ties through. I'll try to send pictures when I get home from work.
