I have an '84 Venture. I just fixed my 4th gear loss problem and put the clutch back in. Now I can'y pull the clutch lever.....
Pulled the clutch back off and still can't pull the lever....steel rod doesn't move at all...
4th gear? Never heard of that but a 2nd gear problem....
The rods coming thru are probably not right, you'll have to pull the slave cylinder off the left side of the bike so you can get in there and push the rods out to the right side.
No, the washer was in the right place....just pulled the slave cylinder off and put it back on...very big pain. I will let you know. I pulled the clutch lever when it was apart so maybe I jambed the slave cylinder or something....still can't figure it out.
You may also need to loosen the bleed valve on the slave.
RandyA
Does the clutch seem to be disengaged as it sets now? Put it in gear & see if wheel will rotate
Just a guess, but when it was reinstalled, something in slave is hanging up, fully extended, thus disengaging clutch. This would then allow for no further fluid to be pushed into slave, thus giving a solid clutch lever.
Gary
Ok, I figured it out.....Make sure the pressure plate is lined up with the clutch boss...I missed that part. After tearing off the slave cylinder 3 times I decided the piston was being pushed too far and getting jambed so it would not release....When the pressure plate is on wrong this happens. Now that I put it back together all is well...Thanks for all the help !! I'm going riding...
