Naked Rider Posted June 15, 2011 Posted June 15, 2011 my fuel pump went out the other day took pump off connect the two lines got it home no problem. i am going to buy a MR gasket fuel pump will the connector work or do i need to cut and splice the old plug on to it? thanks
Dave77459 Posted June 15, 2011 Posted June 15, 2011 Are you talking about the electrical connector? My Mr. Gasket came with bare wires. I cut off the old electrical connector and spliced them in. I note that the new Mr. Gasket pump had a different configuration than the old. The old one was pretty easy to make work, but the new one had two fixed nipples, if I recall correctly. Have fun! Dave
Naked Rider Posted June 15, 2011 Author Posted June 15, 2011 thanks Dave i havnt bought it yet picking it up friday i just assumed it had a plug on it. do you know what color wire goes to which side?
wes0778 Posted June 15, 2011 Posted June 15, 2011 thanks Dave i havnt bought it yet picking it up friday i just assumed it had a plug on it. do you know what color wire goes to which side? Part #? Supplier?
Naked Rider Posted June 15, 2011 Author Posted June 15, 2011 the MR gasket part number is 42S getting it at O rilleys auto parts $45.99 and tax
OB-1 Posted June 15, 2011 Posted June 15, 2011 thanks Dave i havnt bought it yet picking it up friday i just assumed it had a plug on it. do you know what color wire goes to which side? I'm not Dave, but I just did this a week or so ago on my 06 RSV. The blue wire should be spliced to the red wire and black to black.
OB-1 Posted June 15, 2011 Posted June 15, 2011 You'll also need a 90 and 45 degree brass fittings and a barbed fitting.
Naked Rider Posted June 15, 2011 Author Posted June 15, 2011 OB1 mine to is a 06 you said a 90 and a 45 do i connect them with a new rubber gas line?
OB-1 Posted June 15, 2011 Posted June 15, 2011 Ideally, you need a barbed union to extend the formed fuel hose from the fuel filter to the pump intake. The pump intake is where you'll use the the brass fittings. I didn't have a barbed union so I relocated my fuel filter and used a few inches of "new" fuel hose. This made putting the side cover back on very difficult which is why I recommend the barbed union. Here's a link to a post made by "Ponch" that has nice photos. These photos were invaluable to me: http://venturerider.org/forum/showth...ump#post381479
Naked Rider Posted June 15, 2011 Author Posted June 15, 2011 ok thanks you have been a great help on this matter:cool10:
Ponch Posted June 15, 2011 Posted June 15, 2011 http://i672.photobucket.com/albums/vv87/dawarren77377/Bike%20shots/DSCF3264.jpg If you can still find the pump without the barbed nipple on each end, buy a 45° & 90° brass fitting like above. If all you can find is the dual nippled pump, most auto supply stores sell 90° rubber ends you can splice to the fuel line extention to accomplish the same thing.
Naked Rider Posted June 15, 2011 Author Posted June 15, 2011 ok thanks Ponch i will look at it when i get it friday. do you have it mounted or just laying free behind the middle cover?
Ponch Posted June 15, 2011 Posted June 15, 2011 http://i672.photobucket.com/albums/vv87/dawarren77377/Bike%20shots/DSCF3283.jpg It's mounted.
