With tire changer I made. Have had for long time auto changer simular or same as HF. pic 1
Only permement mod was to weld a 5/8 nut to top. pic 2
Cut hex to fit 5/8 nut in 1/4 plate and welded to old 14-15 auto rim(anti rotation). pic 3
Just set rim over nut on stand. pic 4
Tread 5/8 all thread into nut to tight(notice hole at top for screwdriver shaft). pic 5
Another piece of 1/4 plate with 5/8 hole and 5/8 jam nut secures auto rim to stand. pic 6
Split rubber tube on edge of auto rim protects MC wheel. pic 7
MC wheel placed down all tread. pic 8
5/8 washer and another nut secures MC wheel to auto rim/stand. pic 9
Piece of plastic water pipe protects all thread-threads when tire spoons pried against. pic 10
Final view. pic 11
Also built balancer with lumber. Appears to work, same spot of existing tire/wheel always stops same.
Now I just need to commit to do it.
Edited by bkuhr
I have a suggestion for an improvement.
I used to use a similar set up, except it was mounted on a bench. I also put a hole in a length of 2x2 and used a nut to run it down the all thread. I could tuck the end of a spoon under it to hold the starting point as I worked my way around. I could also put the spoon out under the end to hold the bead down as I worked a new tire on.
http://xjbikes.com/modules/coppermine/albums/userpics/10730/thirdhand2.jpg
It's been awhile since I used it. I think that extra block probably gave me something to tighten against so it didn't spin or cock up.
I was able to get rid of that pesky third arm and hand that made it really hard to buy shirts.:rotf:
One area that some people have a problem with and that is the initial breaking down of the tire away from the bead. I have found that a vise works good at times. The other thing is use plenty of lube like soapy water to take the tire off.
RandyA
