BigBoi Posted November 6, 2010 Posted November 6, 2010 I recently purchased a Rivco Center Stand for my Venture. The install was pretty simple and all was well until one morning last week I had a hell of a time getting the bike off the stand, it just kept sliding on the garage floor. Never, ever had a problem putting it on the stand or taking it off before. Now the only way I can get the bike off the stand is to jack it up and take stand off. Any suggestions:icon_smile_question
davecb Posted November 6, 2010 Posted November 6, 2010 Put a piece of nonslip rubber under it before you set it on the stand...
Condor Posted November 6, 2010 Posted November 6, 2010 I recently purchased a Rivco Center Stand for my Venture. The install was pretty simple and all was well until one morning last week I had a hell of a time getting the bike off the stand, it just kept sliding on the garage floor. Never, ever had a problem putting it on the stand or taking it off before. Now the only way I can get the bike off the stand is to jack it up and take stand off. Any suggestions:icon_smile_question Other than putting it on a rougher surface you might check the pivot bolt to see if it might have tightened up on you. You might also put a little lube on the yoke. The feet are smooth so they don't 'bite' like some of the others and have a tendency to slide if there's any sort of mechanical resistance.
Sgtglenn Posted November 6, 2010 Posted November 6, 2010 A few years ago I had similar problem with my Rivco stand. Found the stops had bent back a slight bit placing the stand at a more severe angle when engaged (rear tire just grazing the floor when up on stand) that made it about impossible to get bike down. Contacted Rivco , sent stand back and they replaced the stand at no cost to me. I no longer sit on the bike to rock it off the stand and thing have been perfect since. To get it down I reverse the up process while standing at bikes side.
Freebird Posted November 6, 2010 Posted November 6, 2010 That is most likely the problem. I know that when I was building and selling my stands, I had to be very careful that I designed them to NOT break over too far. If they did, it was almost impossible to get them off the stand.
BigBoi Posted November 7, 2010 Author Posted November 7, 2010 Thanks everyone for your help, I hope the stand is not bent. I purchased it on ebay and will be next to impossible to return.
MikeWa Posted November 9, 2010 Posted November 9, 2010 I had the same problem with my bike and Rivco stand at work. Bike slid all over on the smooth floor when I was trying to take it down. Now I just put a piece of duct tape on the floor in front of the stand. A bigger issue I had was the foot on the right side dragging on hard right turns or going over a bump during a right turn. I got worried about it catching during a high speed turn so I ended up grinding the corner off. Now the running board scrapes well ahead of the center stand. And there is no longer a sharp edge to anchor me. Mike
BigBoi Posted November 15, 2010 Author Posted November 15, 2010 Put a piece of nonslip rubber under it before you set it on the stand... This is the solution people! Works very well. Thank You:fatsmiley:
