Leveling Links - Raising the Rear of the RSV
  • 3 months later...
  • 3 years later...
I received the following note from one of our members regarding the Carbon_One lift adapter. Just a little heads up for those of you who might run into a problem with it. The lift adapter is almost a must have item for our bikes but this may be one case where you won't use it.
"Today I installed leveling links and ran into trouble by using the Carbon One adapter. With the adapter I was unable to get one of the bolts out of the way. I had to lower the bike - remove the adapter, jack it up again, and then it was easy."
