bkuhr Posted May 9, 2010 Posted May 9, 2010 83 VR I have never rode this, got it non-running. Was told clutch was bad so replaced friction plates first thing, during assembly, could see plates spread out during clutch lever pull. Then had major engine problems, and had to remove engine. Now engine back in, runs-sounds soo good, feeling good. Put just enough back together to put seat on and go for test ride. Down off stand, idling, brake on, clutch in, kick down to 1st,clutch out....stall:crying: Then I couldn't put it back in neutral:mad:. Up/down/up/down/all the way up-4 down, no neutral. Finally saw neutral light come on nearly all the way up. HA. shifter backwards, easy fix:happy65:. No one ever done that, right? Now current problem, still no clutch release. bleed/beed/bleed/././. bleed with mity vac, pulled clutch slave, found torn dust seal-not likely problem but rebuilt slave, bleed/bleed/./..., bleed master banjo, bleed master with finger and hose off, tried handle tieback all last night, bleed/bleed/bleed. Feels like good pressure with finger on master-sprays around finger, but down at slave when cracking bleeder fluid comes out in stream but does not spray as in normal bleeding. any suggestions?
dingy Posted May 9, 2010 Posted May 9, 2010 Did you have clutch push rod out of engine? If you put it in backwards I believe it will give you these symptoms. There is a dimple in the end of rod that goes towards right side (clutch side) of engine. The ball bearing sets in this dimple. Middle picture is towards slave cylinder. Last picture is towards clutch plates. Gary
Rocket Posted May 9, 2010 Posted May 9, 2010 83 VR Now current problem, still no clutch release. bleed/beed/bleed/././. bleed with mity vac, pulled clutch slave, found torn dust seal-not likely problem but rebuilt slave, bleed/bleed/./..., bleed master banjo, bleed master with finger and hose off, tried handle tieback all last night, bleed/bleed/bleed. Feels like good pressure with finger on master-sprays around finger, but down at slave when cracking bleeder fluid comes out in stream but does not spray as in normal bleeding. any suggestions? Did you put the splined washer between the inner hub & outer basket upon re-assembly, or under the nut??? If under the nut, you need to pull the clutch again & put it between the hub and basket. I have seen this error, lock up the clutch before, regardless of master / slave cylinder action. :bang head:
bkuhr Posted May 9, 2010 Author Posted May 9, 2010 Only had clutch side rod and ball out. Wasn't paying much attention, but I think end of rod on slave side was rounded.
bkuhr Posted May 9, 2010 Author Posted May 9, 2010 Did you put the splined washer between the inner hub & outer basket upon re-assembly, or under the nut??? If under the nut, you need to pull the clutch again & put it between the hub and basket. I have seen this error, lock up the clutch before, regardless of master / slave cylinder action. :bang head: I really don't remember, was way back in December did clutch. Guess I'm going to take apart again. What else should I be looking for while I'm there.
bkuhr Posted May 10, 2010 Author Posted May 10, 2010 OK, pulled clutch cover and suprise!! Looks like clutch is working. Maybe my problem is above the shoulders?? Started with shifter reversed, and when kicked down to 1st, actually went to 5th and stalled. Then started checking clutch release in actual 1st and trying to turn rear wheel with hand. Is there to much drag normally to turn wheel with hand? Measured clutch release: pic1 clutch handle tied down, pressure plate outboard, mic reset to zero pic 2 clutch handle released to normal, pressure plate inboard, mic read .071in Is this about proper amount of release, or do I still have problem? Should I just put all back together and try again, then put all above shoulder in the sand?
Rocket Posted May 11, 2010 Posted May 11, 2010 Is this about proper amount of release, or do I still have problem? Should I just put all back together and try again, then put all above shoulder in the sand? The cover is off, so pull the pressure plate off & look at the inner hub boss nut, is the splined thrust washer placed under it & the locking tab??? If so, you need to move it, so it is between the outer basket & inner hub. Not having the thrust washer in the correct location, will produce the effect of basket & hub locked together. It may be an idea, to verify, that it was even placed in between the hub & basket (not accidently left out during re-assembly). Remember to re- torque the boss nut afterwards & re-assemble the clutch assy.
bkuhr Posted May 11, 2010 Author Posted May 11, 2010 Rocket, thanks for reply are you talking about item #2 in pic will check tomorrow
Rocket Posted May 11, 2010 Posted May 11, 2010 Rocket, thanks for reply are you talking about item #2 in pic will check tomorrow Yup, it is splined & that in itself, throws people off... They think, it goes under the boss nut, if not checking the parts diagrams.
bkuhr Posted May 12, 2010 Author Posted May 12, 2010 Looks like Rocket hit it right on Splined washer was under lock nut, and realized something wrong when loosening bolt,and inner hub and outer hub locked together until nut broke loose, then inner hub started rotating including pics for others
Rocket Posted May 13, 2010 Posted May 13, 2010 Looks like Rocket hit it right on Splined washer was under lock nut, and realized something wrong when loosening bolt,and inner hub and outer hub locked together until nut broke loose, then inner hub started rotating including pics for others Ok, give another update, after getting it back together & putting a few miles on it, if a valid plate is on the scoot......
