I need thoughts "pro or amatuer" on a gps mount. I am thinking of the N-B238U standard mount on the plastic cowl, forward and to the left of the gas cap. a 3.5" arm N-B201U to get the unit up closer to the speedo and cass. player. I have the garmin nuvi 255w and i'm thinking this will help keep it out of the wind and weather. the steering should go lock to lock without it beeing in the way, i think. any thoughts please chime in, thanks. tired of getting lost......
hard to tell from pics, is that what you did?? thats the look i'm going for. what parts and #'s did you use ??
OK...the Zumo 6600 came with almost everything, however the 255W will have separate parts...but I have found this info before for some of members on my site (arkansasbiker.net)...so give me a little while and I will post all the parts you'll need...including the wiring harness for the 255W.
Wally
Ok here you go....
The Mount is from Cycle Gadgets:
http://www.cyclegadgets.com/Products/RAM/ram.asp?prod=RAM-NUV2W
The handlebar part:
http://www.kuryakyn.com/index.cfm/go/Home.ProductDetail/catID/22/scID/135/IMID/375
NOTE: I bought 2 bolts at 1 1/4" long at Lowe's for $0.11 each.
The Ram Ball
http://www.cyclegadgets.com/Products/orderbysku.asp
And finally the power cable:
http://www.gpscity.com/gilsson-bare-wire-power-cable.html
Hope that helps...I can assure you that you'll like the system once you get it all together.
Wally
