dingy Posted October 31, 2009 #1 Posted October 31, 2009 (edited) I am in the process of installing cruise control on my 1983 Venture Standard. I have purchased almost all of the items I need to do this upgrade from ebay. Prior to installing the parts, I will be disassembling the ones that I can and cleaning them. I have made the following write up of the process of cleaning the throttle side switch housing that came off of a 1988 Venture. The pictures show the switch completely removed from the bike. It is fairly lengthy, 41 pictures, but thorough. I would recommend removing switch from bike if you perform this cleaning. There are a number of small springs and ball detents that are very easy to lose unless you have a large well lit working area. If you are unable to open the PDF file, PM me with your email address and I will send it to you. Let me know if you find this helpful, as I also have the left side controls, brake and clutch switches I can do. Picture below is of the switch detailed in this PDF file. 37950.pdfFetching info... Gary Edited February 14, 2016 by Freebird
