SteveP Posted August 5, 2007 Posted August 5, 2007 Repeating a mod from previous bikes (and as posted a couple of times here), I wired in and mounted my garage door opener today. I put it on the plastic flange/cover just above the gas cap. Just wanted to share this mounting location in case people are looking for options other than mounting the button on the dash. There was plenty of room to stick the opener under there, the push button is pretty unobtrusive and I can get to it easily with either hand. Drilled a small hole in the opener case for wires which I soldered to the switch contacts of the opener. Drilled a 1/2" hole in the flange/cover to mount the push button switch from Radio Shack ($4). Popped everything back together, tightened up the two bolts and it's time to hit the road again. Pics below....
Bubbajbi Posted August 10, 2007 Posted August 10, 2007 I am going to do this. I think it would be easier that blindly feeling around (BY THE EXHAUST) for the button on the side cover. Thanks for the tip.
Venturing Sole Posted July 18, 2009 Posted July 18, 2009 Slight variation to the work of other more creative people. I mounted a garage door button similar to SteveP and photo-documented the procedure that others may find helpful. David
FuzzyRSTD Posted July 18, 2009 Posted July 18, 2009 Wow, such great ideas. Thanks you all. I was just wondering this evening coming in from Church, as to what could be done for that agreavating garage door opener. Thanks again.
LilBeaver Posted July 18, 2009 Posted July 18, 2009 Great idea!! I have been keeping mine in my pocket (without the silver clip) and it works fine for me.
Seaking Posted July 18, 2009 Posted July 18, 2009 Repeating a mod from previous bikes (and as posted a couple of times here), I wired in and mounted my garage door opener today. I put it on the plastic flange/cover just above the gas cap. Just wanted to share this mounting location in case people are looking for options other than mounting the button on the dash. There was plenty of room to stick the opener under there, the push button is pretty unobtrusive and I can get to it easily with either hand. Drilled a small hole in the opener case for wires which I soldered to the switch contacts of the opener. Drilled a 1/2" hole in the flange/cover to mount the push button switch from Radio Shack ($4). Popped everything back together, tightened up the two bolts and it's time to hit the road again. Pics below.... Good job.. I have mine mounted on the LEFT side so that I can reach it while still approaching the garage (so that the door will be open by the time I get there..). I took the guts out of the case so that it fits better under the cover (bulky remote)
Eck Posted July 18, 2009 Posted July 18, 2009 I mounted mine on the back side of the headlight switch housing. I used the chrome piece off an ink pen. I had to drill the hole diameter a little bigger and installed a wired up switch, and filled the chrome piece with black RTV making it water proof. Ran m wires to the garage door opener as shown in above posts but my opener was located between the left front fork and rear side of fairing held on by velcro.
Sylvester Posted July 18, 2009 Posted July 18, 2009 If I do this mod will my garage open, even though I don't have the opener on the door? That would be cooooooolllllll.
droupou Posted November 5, 2015 Posted November 5, 2015 I also removed the cover. Mine is on the right side, but I can still get the door open before I arrive. I didn't take enough pics, but here is the finished product. ... It won't let me upload the image...
Wizard765 Posted November 5, 2015 Posted November 5, 2015 I really like this one but might be harder to install
Flyinfool Posted November 5, 2015 Posted November 5, 2015 I really like this one but might be harder to install Install is not so bad, it is the maintenance and upkeep that are the killer.
Bert2006 Posted November 5, 2015 Posted November 5, 2015 Slight variation to the work of other more creative people. I mounted a garage door button similar to SteveP and photo-documented the procedure that others may find helpful. David Just found my next project
JDaniel Posted November 5, 2015 Posted November 5, 2015 Menard's has a garage door opener for your key chain. It allows you to program three doors on it.
stanG Posted November 5, 2015 Posted November 5, 2015 I did this a few years ago on my 1st gen. Since I don't have the stock radio, I wired the remote to the momentary switch for the radio that was already on the handlebars. I believe it was used by the stock radio to change channels. I tucked the remote into the left side fairing. Works great.
Great White Posted November 6, 2015 Posted November 6, 2015 I gutted a rolling codes homelink sunvisor for the controller and buttons. Going to be mounted in fairing of my 83. It's programmable so it doesn't matter if I move to another house with a different opener. Will also work with other homelink devices like automatic gates, lights, etc. Wired to the bike's 12v electrical system so no batteries to change and it's always available.
videoarizona Posted November 6, 2015 Posted November 6, 2015 Great idea!! I have been keeping mine in my pocket (without the silver clip) and it works fine for me. Yeppers...me too! But I do like the idea of buying a couple of remotes and mounting them hidden on the bikes. Getting tired of trying to remember which jacket has the remote!! Grins!
