Carbon_One Posted July 10, 2011 #1 Posted July 10, 2011 (edited) This weekend I finally got around to remeding the fast flash of the led lights I have on the back of the bike. I had tried a couple of the load balancers in the past without success except for the last option I tried yesterday. Anyhow I ended up using a Custom Dynamics Metric Signal Stablizer -- http://www.customdynamics.com/loadequalizer.htm#Metric_Signal_Stabilizer I put the stablizer under the right side cover and attached the wires to the flasher. Works great now with a flash rate that is much more normal and consistant with the 4 ways and stock flash rate. There is one drawback to attaching it there and that is you lose the self cancelling feature. I can live with that since I usually cancelled the lights anyhow. Old habits are hard to die. Larry UPDATE: Today I realized that the turn signals are indeed self cancelling after all. Edited July 16, 2011 by Carbon_One
friesman Posted July 10, 2011 #2 Posted July 10, 2011 Well this wasnt what I thought it was going to be..... Brian
Carbon_One Posted July 10, 2011 Author #3 Posted July 10, 2011 Well this wasnt what I thought it was going to be..... Brian Sorry to disappoint ya there Brian. Larry
Seaking Posted July 11, 2011 #4 Posted July 11, 2011 Well that's ONE spot I didn't think of trying the various load equalizers on my bike.. What wires did you attach them to? Which wire does what ect? Thanks in advance.
Carbon_One Posted July 11, 2011 Author #5 Posted July 11, 2011 Wired as follows: Signal stablizer unit to flasher connector - function 1. black to black - ground 2. blue to brown / red tracer - power with key on 3. brown & purple (2 wires) to brown / white tracer - turn signal output I tested with both brown and purple by themselves and it still functioned the same as it did with both wires attached. Rather then leaving a single wire hanging I attached both. I took out the terminals at the connector, soldered the controler wires to them, and then reinserted the terminals back into the connector. Leaving a nice clean connection. Larry
Carbon_One Posted July 16, 2011 Author #6 Posted July 16, 2011 (edited) UPDATE: Today I realized that the turn signals are indeed self cancelling after all. I don't know if they stay on longer or I was impatient on them going off. Whatever now that I know they'll cancel I'll try to see if the flash duration has changed or not next. Larry Edited July 16, 2011 by Carbon_One
