Guest pkksr
I am looking at replacing the stock turn signals on my 07RSV. Any suggestions?
Get some 2357A bulbs from the autoparts store and cut off one of the pins. You wil have to look at your factory bulb to tell which one to cut off.
The 2357LL bubls work GREAT in the stop lamp!!!!
Inexpensive and quite a bit brighter.
Squidley asked me about my turn signals at Kitchener. This is where I got 'em. They're VERY bright, and the Eclipze version for the front is pretty cool.
You can get the three pin bases for the newer fronts. I had to run a file around the outside once or twice to get a perfect slip in fit. I didn't use a load equalizer. They flash a little fast, but no faster than if there were one burnt out, which doesn't bother me at all. Might even make 'em more noticeable.
Guest pkksr
Thanks, I will check them out. Looks like the wiring is the same as stock, you just needed to file to fit in the stock signal?? Thanks
The aluminum/fiber plates were the tiniest bit too big to just slip in on two of them. A light swipe or two with a file around the outside edge slipped 'em right in, good and snug. They fill the entire bezel opening.
The pigtails plug right in to the sockets. Remember that the newer bikes ('05 and newer, I think) are three pin in the front.
Here's a pic showing the difference between stock and the LEDs. The brakes are not on. The tail light is a 128 LED board by RadiantZ. Right now I'm trying to figure out how to change the wing lights to ultra bright LEDs too.
Edited by Bummer
Added the pic
