abusive throttle cranker
Expired Membership-
Everything posted by abusive throttle cranker
Got 'er runnin!
abusive throttle cranker replied to abusive throttle cranker's topic in Watering Hole
When I said they weren't especially spongy feeling I should have mentioned I have already bled the rear- then the front. I wasn't aware at the time of the fitting up near the triple trees. Still- air in the system makes em spongy. But why such effort needed to get some response? BTW I've gone thru- all the pads but one were good and I replaced that one. -
Well shes running finally! And I took it around the block. Couple questions though. Does interconnecting the brakes yield high pedal pressures? It isn't especially spongy feeling but I do haveta stand on it to get some stopping power. The front ain't so bad. Another thing: it has more decelleration than I'm used to. When I shut the throttle it really slows. No- its not the brakes. Put it in neutral it'll roll. Of course I don't have the idle set yet. With the adjustment buried behind that emissions canister I gotta get home and let it cool b4 I can wiggle my hand in there enough to turn it. Other than that its running pretty good. I'm sure it could smoke the Suzuki VL1500 I was riding. It did backfire a couple times on decel. I put a couple ounces of Techron in the fuel and ran it enough to get into the carb passages. It has 2 half inch holes cut into the air box. I covered them with duct tape but still the square duct piece inside the air box is missing. The one protrudes inside the filter. Is that thing critical? I'd appreciate any comment y'all care to make.
Replacment fuse block
abusive throttle cranker replied to etohio's topic in Venture and Venture Royale Tech Talk ('83 - '93)
He has the panel with 8 fuses there. Earl's has 6. But he also has the handy-dandy instruction sheet -
And then theres fiberglass. My brother used it on his poorman bass boat. If he can use it anybody can! Seriously though- FG is a common application for cars and ain't so hard to do.
Yeah thats it- the 3rd pic. It had a left side kick start on it. Just for giggles- the 305 Honda Super Hawk had a right side kicker- but it went clockwise! Yup- ya kicked it foreward! That Honda Dream u show there is the 160cc version.
I had one looked just like that- in blue. Mine was called a YM-1 I think. Also called the 305 Cross Country. Used ta whoop up on Honda 350s. Of course I only weighed about 130 lbs at the time!
I don't want to introduce a downer attitude here but........what purpose is served by these posts? Send the man some money and done. He'll know who u are and of course u know. And of course the man (or woman- politically correct here lol) upstairs. Why tell all of us?
Battery question
abusive throttle cranker replied to mralex714's topic in Venture and Venture Royale Tech Talk ('83 - '93)
I considered something like that for its low weight. But then I realized the 18 lbs of a normal AGM battery is actually less than a full tank of fuel which is normally carried above the engine, I went with the proven technology and half the cost of the AGM design. -
Customer Service- the Partzilla way
Ya right- the fine print! Of course! Regardless of fault! I say again- they will gain- regardless of customer satisfaction! How can they screw up 3 out of 3? Its.........amazing! And the fee they charged me was 24%. Scumbums. -
Hmmmmmm......I'm just going by what I've been told. "Send it as a gift please so they don't charge me". I use PayPal for purchases only- taking money out is a foreign experience. -
I used PayPal. Will they fight a company for a restocking fee? They did, after all, refund (76% of) my money. They just helped themselves along the way. Aside from that- the refund went into my PP account. Which means I must use it for other purchases or they will levy a fee on me if I try to extract it. -
They never offered to send replacements. And being Oh- fer I didn't want to continue to try with them. I sent them a nasty email. At the rate they 'work' they won't see it for 2 weeks. They'll probly delete it after seeing the first 3 words. -
The 2nd gen has a cable? Its not hydraulic? If hydraulic be aware that the brake fluid will degrade under high temperature. I've had it happen myself. Try bleeding the clutch. If burnt the fluid coming out will be dark. If that is the case you must bleed it till clear fluid comes out. My 1st gen uses DOT 3 fluid- better check to see what yours takes.
Weeks ago I ordered 3 items from these people. The total was $170. All 3 items were wrong- in spite of my sending a couple of followup emails to make clear what I intended. And being assured all was in order. So I obtained an RMA and returned them. Total shipping cost both ways equaled $40. The return shipment was posted on 4/09 and the USPS said it would arrive on 4/15. This morning I finally received a refund. For $129! They charged me a restocking fee! To fix their own error!!! Be warned! This company doesn't give a damn about the customer- they gonna get ur money!
I am a retired truck driver and still have my CB radio and antenna. The antenna has the standard fittings used in the US. It will NOT fit the stud on my 1st gen.....
Newest 1st Gen MKI & MKII Crown Patch Prices
abusive throttle cranker replied to GolfVenture's topic in Watering Hole
Yes please! One 5" and one 11" if u will.
