  1. I have the 950 Tourer and need to put a new rear tire on her. I know some of you have had this bike before and may still...so I'm asking: Where do you position the lift underneath? I looked under there and have tried, but can't seem to get a good position for a simple lift!! So what am I doing wrong here?? TIA, david Must be me but I'm just not seeing where I can get both lift arms underneath...either bike is to wide??? or ??? Works fine on both Ventures...
  2. https://www.youtube-nocookie.com/embed/xh9GaDgRWX4?rel=0 Enjoy, david
  3. Is that big hose on the cannister connected to the fuel drain on the carb? I don't think it is as I think I see the two drain hoses sitting where they should be. So where does the big hose go? Is there one cannister to each carb? I don't have a California bike so this is new to me.
  4. I quit cold turkey in 1986...when my 4 year old complained to me about the smell....and I ran out of packs on the day before I should have. Was easy to do since I was mad enough! That's all it took for me. Go for it my friend. You will be much happier (and have more bux in pocket too) in the long run.
  5. Welcome to the nuthouse! In addition to above: Drain and put in new brake fluid in brakes and clutch masters and systems. All use Dot 3. Get vacuum bleeder from Harbor Freight. Easier to bleed. Note there is a bleeder just below steering stem, if memory serves. That bleeder is between rear brake and left front... which are linked. Right front is on right handlebar. Bleed rear first, then middle then left front. Note also rear master resevoir does not have a sight glass and the neck can break off if nut is frozen. Use WD to soak nut. Proper level is just below threads. Used rotors can be found on Ebay. Your bike is a 1st generation, Mk2. Most parts from 86-91 will fit. Pull plugs and throw. I would also get new spark plug wire set. They are resistor wire sets and can be found on E bay as well. 5k ohm sets. Clean all electrical connectors, put back together, then coat with dialectric grease to keep moisture out. On lower left by passenger pegs in frame area is a plug with three white wires. Take apart and look for burning. They are the charging wires from stator to regulator. If they get dirty, they get hot and can burn or melt. Keep clean and you are good to go. E4 error is a simple fix on the CLASS system. Take apart computer and resolder the larger solder joints and white connector goes into board. Pics and write ups in 1st gen tech section. Download a copy of shop manual from this site. Again, welcome! You have picked up one of the finest handling scoots around. Once you have gone over your bike and got it all sorted out, you will be pleasantly surprised at how fast it is and how comfortable for long rides! david
  6. Sorry,I gave it to another member here...
  7. I used to use Sta-Bil on my outboards. But after this past year... where I had to rebuild both carbs on both motors.... No more. It's simply not good enough for long term use. The crap gas obviously does a better job of fouling my carbs than Sta-bil does in protecting them!
  8. Interesting! I'm right hand yet i find slow left turns easier than right!!
  9. I love Tourmaster 230's on my 89 Venture. After two years they still look and ride great!. Don't know the miles, I just ride. Since the 230's have been so nice to me on VR, I'm going to put a 777 on the rear of the Vstar 950t.
  10. All the above. Slip clutch, throttle on, pressure on rear brake, turn head and look where you want to go. That's the technique. Rest is practice. Oh..keep feets on pegs!!
  11. I'm running the Routes on my 05 RSV. Handles well, quiet. I'm good with them.
  12. HD mufflers bolt right on with easy to make hanger adapters and have a nice rumble. Not to loud at any speed. And available just about anywhere cheaply!
  13. Could be a venturi effect at the bottom of the hill. ps. I spent a week in your town. Enjoyed it.
  14. Chapel of the Holy Cross.....Sedona, Az
  15. I'll be back up Wednesday. May ride 05 RSV. Lets see if we can meet up...
  16. Ugh. What's going around lately isn't fun. Took me out for over a week. Take care and get well soon!
  17. Sorry to hear about your brother! Helmets. I would read up on as many helmet tests as you can find. Go to cycle gear dot com and read up on the different brands... Especially the readers reviews and comments. If there is a Cycle Gear near you... Call and see if they have one that may interest you on the shelf. If so, go and wear it around for an hour. Bring a book... Sit and read. See how your head feels. Fit is primary on any helmet but more so, I feel, on a full face. You can get an idea about noise protection by the amount of store noise you can/ can't hear. As far as noise..... In theory the more $$ you spend on a helmet, the quieter. Not necessarily so. If you get a good fit, then cheap foam earplugs are your best bet, seriously. I now have tinnitus and severe hearing loss because I didn't wear ear protection. I wear plugs now! Good luck and let us know what you find. Many of us are still looking for a good helmet that is quiet too. My Sedici is better than my scorpion... But neither I would wear without ear plugs.
  18. Rodney, did you ride or drive to Sedona?
  19. I've given up trying to get in. By the time I realized I really should sign up, it was real tight here in Phoenix. Even with an advocate, it seems there are too many vets more qualified than me. That's OK, though. They need and deserve it more than I.
  20. Ah,man...I was happy with the previous thoughts. Regardless. I believe it's just older gaskets and O rings and not dangerous... Just an annoyance. Extreme temp differences within short periods of time, which we get in Arizona, will cause this problem with older parts. I'm going to consider it a positive.... My 89 is talking back to me!
  21. Bill, you may be on to something. Makes sense to me. Mystery solved, IMHO!! I know with O rings our scoots have a tendency to leak once in a while, maybe the O ring is shot..... That would be a simple fix. Thanks. I'm not going to worry about it until I get the 89 back home. Add this to my list!
  22. That's sad. Sorry to see that, Steve...
  23. Agreed. Hence the conundrum. She doesn't leak after a run in Green Valley, and I'm at 3k feet elevation at my house there vs 1600' ish in Phx.
  24. Well, it's official. Been two years but finally got the 89 1st gen back to Phoenix yesterday. Great ride. But this morning, she marked her spot with coolant. She really doesn't like Phoenix!! Guess I better hurry and replace tires on VStar 950.... So I can bring the Blue Beastie home to Green Valley!
  25. Update: Overflow bottle still clean, so can only conclude the water pump seals died during the POs tenure as was repaired but not totally flushed out. Will keep an eye out... Thanks for ideas and help!
