AH...good one! The CB squelch will cut the audio signal as signal strength from the CB receiver changes. Never would have thought of that....since I only use CB when with a group. Good catch!
I want a tall vented tinted windsheild
videoarizona replied to baylensman's topic in Royal Star Venture Tech Talk ('99 - '13)
I have the largest Clearview with vents for all 3 scoots. VStar, 89 VR and 05 RSV. -
Additional Driving Light...
videoarizona replied to s.tyler58's topic in Venture and Venture Royale Tech Talk ('83 - '93)
Stan, interesting modification you made!! Like that. I remember morning drives into the station. Especially in the winter after a snow...I would be on the road before the plows! Side benefit, the donuts i picked up on the way were really fresh! Loved morning drive shift. Good memories! -
Yep. Papa, these scoots like to rev. Use seafoam as directed in can. I use it every other tank. To clean, heavier dose.. Run it for a few minutes to get the treated fuel into the system then let her sit overnight. Next day or two, take off and zoom. Seafoam will not usually unplug a hard plug in a jet, but will clean out the carbs nicely. Maintenance.... Change plugs and fuel filter once a year. Change oil and filter every year. Change clutch and brake fluid every two years. That's the basics with these bikes. As far as age.... Sigh... There a are more than a few of us who have had grey hair for so long, we've forgotten what color our follicles used to be!!
Rear Tire Safe or not.
I put the shinko 230 tourmasters on front and rear of my 89. Put the 777hd on the rear of the VStar. Will be putting a pair of 777hds on the RSV. I think the 230 is about the best tire you can put on a 1st Gen. No, it will not give the mileage if you run heavy like cowpuc. But I have close to 9k on mine and they still look great. I like them because they ride smooth and stick like glue, rain or shine, and are a great value! I believe the 777hds have most of the stickiness plus are better for mileage, which is why they are going on the heavier RSV. I'm impressed with Shinko. -
Yikes! Beautiful find! Do send along pics of the 160 when you get the time. I never kept any pics of me in that scoot.
Reminds me of my 1st scoot. Honda 160. Really liked that bike... Thank you for the memories!! david
Annie, I have to put you on the spot....asking for names to go with faces, please... david
That is correct. My XM is sitting on that connector. Leaving me the Aux connector by the cassette to use....if I ever need it.
Easy answer, with no ignition noise, the audio will be clear as a bell. You are right....grounding or wiring. See you when you get back...be safe
Have to say, John, you've come up with a good one. Unless the aux input cable coming into the amp is bad....oh...there is a connector between the two. Dam....just remembered. The aux jack by the cassette door wire runs about 6 inches or so to a female connector that is the wire from the amp. The connector is located about midway between the two. Did you see that and check it? Regardless...see you when you revisit this after your trip. Have a good one and be safe! My pinkie is touching the aux connector that goes from the amp to the aux plug by cassette.
Valve adjustment question
videoarizona replied to videoarizona's topic in Royal Star Venture Tech Talk ('99 - '13)
Update: Did go out for another breakfast run to the border with the RSV yesterday. Started instantly, cold with full choke. Warmed up then idled fine. Ran nicely down the freeway at 75mph. After breakfast, chicken friend steak and eggs this time, she started first time, no throttle, no choke. So I think I have the carb balance spot on. Mileage still low as the gauge dropped quickly on run back. With about 120 miles on odo, the gauge shows 3 bars. For me, that's about 1 bar shy of normal. My RSV hits 2 bars and and within a few miles, I have to switch to reserve. I used to go between 180 and 200 on a tank....assuming both highway and secondary road speeds with reasonable wind. I check mileage at every fill up. So next up, I'll pull air cleaners and plugs and check them. It's time anyway...been a year on both. -
LOL! Who knows what the weather Gods have in store for us! Officially, the monsoon is from mid June to end of September. https://www.tripsavvy.com/arizona-monsoon-facts-2683732 But we have had serious flooding rains in December and April as well. So who really knows! -
More thoughts: 1: Make sure the audio amp ground is good. IE, take it off, use a wire brush to clean both the wire contact and the frame area, put back together. 2: Using an ohm meter, check to see if the signal ground is also the chassis ground. On the OHM setting, put the meter leads on a good known chassis ground, then use like a spare mini plug without wires, or one with a broken off wire (headphones) and check for resistance between the chassis ground and the shield ground...usually the part of the plug closest to the wire end (3rd contact area closest to wire). Do so with the system off. The tip and ring are for left/right signal. Today, and since the beginning of transistorized circuits, some manufacturers tie the signal and chassis grounds together....while others "float" the signal grounds. The latter solution isn't really kosher but works well for the most part. On Motorcycles, where ignition systems/wires run very close to audio, this really isn't a good idea. However, due to circuit design on the amps, etc., you probably shouldn't try to tie the systems together as damage may occur. We simply have no idea how the amp is designed...and no schematics so we could check it out. If we could, the solution could be simple. Most noise on an unbalanced audio input...ie...the aux circuit on the RSV...is coming/traveling along the shield of the cable and not being grounded before it enters the amp system. The problem is how to stop the noise or at least lower the noise floor so the signal is loud enough to be heard without the noise being a bother. Cranking your GPS volume up would work if you could do that. You added a choke to the power of the GPS, so we know that's not the whole problem. If you have an adapter system that adds the GPS signal to the 5 pin cable, then the noise problem is within the adapter as the 5 pin system seems to be pretty well built/routed/shielded. Within the adapter is going to be the circuit that mates the two signals and supposedly does so with the proper impedance (level matching) as well as filters the audio from the GPS AND is a grounded/shielded box to protect from stray RF from getting into the adapter circuit board. That's as far as I can go for now. Awaiting your responses. david
John, From your description, you've been through about everything I would check for. Questions: 1: Is the GPS connected through the aux circuit? 2: cuts in and out? Power or signal? 3: Choke in power wire. Good. But. Did you also look into the signal wire? The aux circuit is an unbalanced circuit, so it will pass ignition noise on through the circuit. Thought: Did you look into re-routing some of the wires or wrapping them with aluminum foil or a metal mesh that you can ground>
No, had an appointment in Tucson this morning early. Will try to get out tomorrow am before the weather hits. We are in our "monsoon" season. Ie, IF the weather pattern is just right, we get rain. So far, after the past 4 weeks of record breaking heat, we have had rain more often than not. Kinda nice actually. Of course, the humidity peaks for a few hours reminding me I could never live in the South! At least I dry up in the July mornings (sometimes) and it's cool enough to open doors in the early am! -
She runs and rides!
Known issue on that year bike. Search forum...lots of choices. -
I bought one for my wife and youngest kidlet. Also gave one to a friend for a present. He ended up using his. It worked! Guess that's the best thing you can say about a product. Check the charge and charge it up once in a while. I keep one in my truck and one goes in the saddlebag of whichever bike I take on a trip. That and a tire pump with a plug kit are most important. IMHO... That one you linked to looks good and price is about right. Did you check Costco or Sam's Club to see what they might have?
Sync'd the carbs after I got back from the breakfast run. Used way to much gas for the little trip down and back.... -
Red low fuel light
videoarizona replied to Kirby's topic in Royal Star Venture Tech Talk ('99 - '13)
> Makes one wonder why this part would go bad. Not much to it, I gather... I can see after 20 plus years the gas would destroy the unit, but not after 10 or 12 years. Wonder if I can simply replace the little thermistor? Probably not more than few bux to buy one.[/color] -
Red low fuel light
Same problem with my 05. I'll do the test to confirm the sending unit isn't working for the light side of the unit. If that's the case, I'll do the same...just go without. Maybe someday I'll find a unit cheap enough to make it worth my while to replace it. In the meantime, I almost always stop for gas before 2 hours is up...as butt doesn't like sitting that long! -
Understand, Jeff. I'm concerned about where the clearances are on the valves. Maybe I shouldn't be as scoot has only 60K miles and supposedly had valves gone through once already. RE: cowpuc...yea....right on this one too. Shame, cause I think he would really like the riding down here... -
Appreciate the positive thinking, Clive! Once I get the parts in, I'll whistle while I work. And take notes and pictures and really take my time!! Grins. What started all this is the PO last year gave me a bag of shims and said he had just done the valves. That was 15K miles ago. And my gas mileage has dropped. Went from 42 at 75 to 38 at 75. I know that was because I corrected the speedo so now my speedo and odo are much closer to accurate, the mpg's will go down. But from 38 to 35.....nope that's something else. This morning's run to the border and back gave me 68 miles ... almost 1/3rd tank. That's not right for this scoot. I usually get about 75 miles on 2 or 3 bars depending upon wind. BTW, I've never seen the red fuel light...I always stumble first and have to switch to reserve before any light comes on. Yes bulb is good. Plugs (iridiums) are less than a year old, slightly used vacuum port plugs so they should be good, everything else looks good. Do need an oil change....but I doubt that's worth poor mpg's. This mornings ride: 1st pic is breakfast at a diner near the border. 2nd pic is another one of those roads to nowhere. You can't CTFW to far on these roads as they stop....nothing in front but desert. I like this area (Rio Rico) a lot. The clouds throw nice mottled light on the hills behind me. They get a lot of rain down here for Arizona. So it's always a bit cooler. If cowpuc ever came down this far, I doubt he would move back up North. Geesh...I just hijacked my own thread....
