My philosophy: Since all this is so esay to do: Plugs. Check each year if Iridium. Change if not. Engine oil, once a year. Before the winter break. Get those acids and stuff out of there. Rear end oil, about every 2 to 3 years depending upon dusty conditions. Use synthetic. Front Shocks, every 2 to 3 years. Cheap and easy. Clutch Fluid. Every 2 years...it will accumulate water and dirt...change it. Brake Fluid. As above. If it's the least bit brown colored....change it. Hint...do them both at same time. Brake pads. Check each year. Rotate RSV rear pads to even wear. Clean and operate the pistons while you are there.. Rear End Splines.(all of them-includes drive shaft) Lube every tire change or every 2 to 3 years. Do these things and the bike will take care of you. Do not do these things in a timely manner and the bike WILL take care of you.
In the post screen where you are typing your message.. there are 3 rows of icons on the top left. The 2nd row starts with a "B" looking icon. In the 4th group on that row (the group with the icon of the camera)....the 4th incon looks like a home screen we used to use to watch mom and dad's home movies. Hover mouse over that icon...it should say "Insert Image". Click on that. Little window pops up. On top you have a choice of getting the image from a url (like google drive) or your computer. Choose one. Then either click on "OK" if using the url or "upload" if from computer. Make sure you have the screen cursor where you want the picture to go in your post. Do suggest you put some space around the picture by not typing right up to it..it./..use the space bar or enter key to give yourself some room. If it doesn't upload (website says upload failed...) the image is to large. Use Photoshop or any image program to get it down to a more reasonable size. That's it...easy.
Crappy, clunky, difficult shifting
videoarizona replied to Semi-retired's topic in Royal Star Venture Tech Talk ('99 - '13)
Clutch fluid flush can be a pain or easy, depending upon your procedure. But seriously, that would be the first thing I would do. Get some fresh fluid and just do it. If you can, get a kit for doing the brake fluid. Harbor Freight. A hand held pump and some tubing. You can open the slave cylinder bleed port, connect tubing to that port, making sure the tube goes up then down...ie...has a loop...to keep fluid always at the connection, put some fluid in the master, then either push it through using the clutch handle (go slow and make sure top is on master) or suck it through using the tool. Keep the master full so you don't suck air in and really ruin your day. Cause getting the air out is a pain. No different than bleeding brakes. As far as changing the clutch discs. That was easier than I thought. There is lots of info on both...search the site. I found the pics and info I needed, downloaded it and went to work. If I can do it...anyone can! -
Got tired of sitting around in the heat...decided it was time to have some fun. Have the RSV torn apart. Cleaning, adjusting, lubricating.... Got to the sparkies. Iridiums. About 8K on them...including that punishing trip back East with headwinds and a full load. They look really good! Even still gapped at 32 thousanths. The tips are clean, the insulators are clean...everything looks fine. (disregard the tip color of #2 plug...they are all the same. Must have been the way the flash hit it.) The pic is before I cleaned anything... So...my instinct says to put them back in. Heck...my Yukon XL went over 100K on the same type iridiums...why can't these go more? So that is the question to the brain trust. What would you do?
Yep. By taking off the rear wheel, then slipping the axle back in...you can tell the alignment. If the axle goes in easily, she's aligned. If not...loosen the acorn nuts, slide the axle in then tighten the nuts. The axle should move freely. I do this anytime I have the rear wheel off. Just to make sure. Besides once you are in there, it's time to grease everything anyway...so why not one little extra step?
Prayers...Bob....come on guy....fight this....we love you, brother!
Lift the lid and wiggle the wires with the bike in "aux" mode. See if the display is intermittent.
Changed my mind. Going to also see if I can get the Gen 2 engine guard braces installed. Got one almost ready to go but forgot which way the little brace goes....time to search the web site and see if I can find the instructions written by the member vendor that made them....always something! Update: Didn't get the braces on. While tightening one of the bolts on the right side brace, the brace snapped. Yep. Guess I'm stronger than I thought....NOT! So much for that idea.
My goal for today is to hope the painters finish painting the house. Downside is I'll have to write a nice big check for them. Sigh. It's only money.... P.S. I like Richard's and Carl's posts better....
https://www.venturerider.org/forum/showthread.php?493-CLASS-E4-Error-Repair
Excellent find! The E4 error. Easy fix. On the right side of the fairing, lift the lid holding the Class control and look down. At the front is the overflow bottle, the rear is the white Class connector going into the controller. That connector strains the circuit board and cracks develop on it. Solder the connector and all should be well again. To get to it, take off the top panel on the fairing, then the Class controller. While you are there, take off the CB antenna cable, clean, check your signal strength and put it back. The rest is easy. Take the controller apart, pull the circuit board and resolder the pins for the connector. Use a magnifying glass to make sure you get a good connection. Put back together and test. Don't over heat the board wit the soldering iron...use a pencil if you have one. I found pics on the forum somewhere.... david
Really good to now a member of our family made the ride! Thank you for sharing...
:sign yeah that: Lots more meets to enjoy! Agreed... Prayers Up, Bob!
Full LED conversion
videoarizona replied to Shadowhawk's topic in Royal Star Venture Tech Talk ('99 - '13)
Sorry for late response...been out of town. I got mine on EBay.... Like here.... https://www.google.com/search?q=led+motorcycle+reflector+lights&rlz=1C1AOHY_enUS709US709&tbm=isch&source=iu&ictx=1&fir=J007NlApwz6ObM%253A%252C8PhIg7M4aJ9i3M%252C_&vet=1&usg=AI4_-kSl3X7wgLQ9NFa_NZhPDRztjfKIYw&sa=X&ved=2ahUKEwjxhsLR9K3jAhVLpZ4KHUmeC3cQ9QEwAXoECAkQBg#imgrc=_&vet=1 Mine are two way...ie...turn and running lights. Look for those with 3 wires. -
Interesting thread. I like CD's too. But didn't want to go to the trouble of finding and mounting a player on the RSV. I went back to cassettes! At least now I can mix my own mixes....LOL! If I can figure out how to mount an SD unit and get it to play well with the controller...I'd be really happy. I just added an SD card to the Sierra truck and have around 5k songs on it. That would be a hoot to have on the bike! As far as foam is concerned, It shouldn't be to expensive! Open cell or closed cell. If it's that bad in your area, find a Harbor Freight nearby and look in their sales stuff. They have instrument type cases on sale right now. Maybe cheaper to buy the case, take the foam out and use that. I don't know...just another off-the-wall-thought from me. But yea, building a simple foam insert for the saddlebag would be a cheap and easy way to go. It also looks like there's enough room to mount the CD unit on one end and leave the other end for tools, etc.. Good luck...keep us posted. Notice the mounting angle limits....below https://www.clarion.com/us/en/products/2007/audio/changers/changers/DC625/us-en-product-pf_1165294763815.html
My new 2018 and what I think
videoarizona replied to dave_wells's topic in Star Venture and Eluder Tech Talk ( '18 - Present)
Dave, on my past 3 Yamaha bikes, the widest and tallest Clearview with vent did the trick for my lady as far as buffeting. Got rid of most of it...making her ride far more comfortable. Hoping this continues for the Gen 3. -
Please Read and RELAX
videoarizona replied to Freebird's topic in Star Venture and Eluder Tech Talk ( '18 - Present)
Me too. But I have to say, I love the old threads and posts. There's so much information here.....sigh...not enough time to learn all there is to learn from the guys and gals that have and still are... around! -
Rich, this is an old thread.....and back in the beginning...the 3rd Gen bike was just coming out..... -
Condor was right...Addictive.
videoarizona replied to Tennessee's topic in Royal Star Venture Tech Talk ('99 - '13)
Has the rear been lowered? Looks like it....the brace hanging down for the rear brake??? BTW, Nice looking bike there! You will enjoy the miles on her, for sure! -
They used to have a lot more products. Mostly VStar 950 and 1300 stuff as well as RSV. I bought my tail light panel from them. Not listed. Ah well...EBay will have more stuff...
It looks like they have dropped all their Yamaha products. Nothing I could find on the website. Shame, as I liked and have bought their stuff.
videoarizona replied to made2care's topic in Venture and Venture Royale Tech Talk ('83 - '93)
Well....the idea of tooling around at any speed on 2 tires that may have internal dry rot and blow out at any time and any speed....you get the message. 4 tires, no problem....2 tires...deadly chance being taken. nope. Nada. Nein. Nej. Non. Tidak. In other words...hell no! Grins... david
