GigaWhiskey Posted May 28, 2007 Posted May 28, 2007 A while back I thought to purchase new lenses for the turn signals and taillight because they were dingy and they would not look good. Then I found Meguiars PlastX Clear Plastic Cleaner & Polish. This stuff works very well with minimal elbow grease. Needless to say, I am not in the market for new lenses. These things are now very shiny This stuff works on the four turn signal lenses, taillight lense, the clear headlight cover, all of the reflectors, the clear dash plastic, the radio glass and the CLASS glass. I love this stuff and thought I would pass it on to all of you! PS. Do not use it on the windshield!
rod Posted May 31, 2007 Posted May 31, 2007 Why not use on windshields, is it acetone based? Lens plastic is acetate based most of the time and you can remove the haze from the lens by wetting a rag in acetone an wiping the lens, wipe the lens quickly then let dry undisturbed till the plastic hardens. Then repeat as necessary and buff when done. Rod
GigaWhiskey Posted May 31, 2007 Author Posted May 31, 2007 For some reason, it scratched mine up and made it blurry. Must be some ind of coating on it. I dunno. I do not want to be held responsible for someones windshield getting messed up, so, I said do not use it on the windshield. All else, what a shine it brings!
a1bummer Posted May 31, 2007 Posted May 31, 2007 I used it on my windshield and it looks great. The back of the bottle reads as follows: PlastX Clear Plastic Cleaner & Polish Restore clarity to clear plastics with PlastX. Cutting-edge advancements in micro-abrasive technology gently remove surface stain to clean clear plastics. Vital conditioning oils restore optical clarity, while highly water-resistant polymers provide long-lasting durable protection. PlastX is non-toxic and does not contain any harsh solvents. USE PLASTX ON: Plastic headlights Plastic boat windows Convertable windows Hard plexiglass surfaces Scratched CD surfaces Then it goes on with the directions, etc. So... no acetone
SaltyDawg Posted May 31, 2007 Posted May 31, 2007 So where can I get me some? My cages headlights are so crazed I'm surprised the light even shines on the road. Wayne
GigaWhiskey Posted May 31, 2007 Author Posted May 31, 2007 I can't remember which place but I got mine at O'Rielly's or AutoZone. Simple auto part stores should carry it.
SaltyDawg Posted May 31, 2007 Posted May 31, 2007 No O'Riellys around here so hopefully AZ will carry it. Thanks
a1bummer Posted June 1, 2007 Posted June 1, 2007 I got some the other day at Advance Auto across the street from O'Rielly's. Like GigaWhiskey said, Any autoparts store should carry it.
Buzzard1 Posted June 1, 2007 Posted June 1, 2007 "Clear Cut" made by "The Wax Shop" Same maker of "Super Glaze" wax-----Buzz
mini-muffin Posted June 1, 2007 Posted June 1, 2007 I picked up the PlastX at walmart. I plan on using it on my headlights as well. Margaret
