Venturous Randy Posted September 4, 2008 #1 Posted September 4, 2008 (edited) I could not attach pictures to your message, so I will try here. I took a piece of steel tubing that was the same inside diameter as the steel wheel and used the outside diameter to determine the hole size needed in the stand foot. I put the sleeve in and welded is so it is still as strong as before. I placed it so the wheel is about 1/8th inch lower than the bottom of the foot. I then used a grade 8 bolt thru the sleeve and wheel. I can take two fingers and with minimal pressure on the side of the trunk, I can spin the bike around on smooth concrete. RandyA Edited December 19, 2017 by Freebird
Gambler Posted September 8, 2008 #2 Posted September 8, 2008 Somebodys thinking out side of the box. Gambler
