Dano Posted August 30, 2008 #1 Posted August 30, 2008 OK, got the "twinkie" (oil cooler?) redone and installed. And the bike actually started and ran after that!!!! However, as some of you know, I've been having a problem with the bike back-firing under load below about 3k on the tach. Just for the heck of it, and checking the pressure (boost) sensor, I pulled the sensor hose off of #2, held my finger over the hole, raised my rpm's to 2500-3000, applied vacuum and the rpm's changed. Sensor good. Put the hose on and decided to check the vacuum on the other cylinders. #2 dropped a little with open tube, same as 3 & 4 (Maybe 100 rpm). However, and this is what is mystifying, #1 when opened up, the idle INCREASED dramatically, almost 500 rpm! HUGE amounts of vacuum on that carb? My question to you'all then, is #1 OK and the other 3 are weak? Or is #1 too high and the other 3 are OK? Could this be tied into my back-firing problem? Inquiring minds NEED to know!!!!! Stupified Dan
MiCarl Posted August 30, 2008 #2 Posted August 30, 2008 Sounds like you need to synchronize the carburetors. #1 has high vacuum (low pressure) because it's butterfly is too far closed relative to the others. It isn't getting fuel/air and the other three are dragging it along. Basically the other three cylinders are working hard to pump a vacuum on #1. When you open up the air flows and the engine isn't working as hard. Engine speeds up.
Dano Posted August 30, 2008 Author #3 Posted August 30, 2008 Thanks MiCarl, I'll hook-em up and see. I had a sneaky suspicion, but wanted to see what diagnoses was. Thanks, Dan
