KiteSquid Posted August 28, 2008 Posted August 28, 2008 (edited) Do any of you have a 1999 or newer H-D Ultra Classic that you use a headset on? I was wondering if they pin out is the same for it and the 2nd Gen RSV??????? Also, I cant seem to find a pinout diagram for the 2nd gen RSV headset, but I can find one for the 1st gen in the tech library. I need one for the 2nd gen. Edited August 28, 2008 by KiteSquid
Obber Posted August 28, 2008 Posted August 28, 2008 You might check out this web site: http://forums.delphiforums.com/vrider If you are not a member you can sign up for free. Close to the bottom of the page has the wiring diagram for the headset plug-in.
BuddyRich Posted August 28, 2008 Posted August 28, 2008 The HD's use a 7 pin configuration so the pinout would be different
Tartan Terror Posted August 28, 2008 Posted August 28, 2008 RSV is the same as the Goldwing if that helps.
KiteSquid Posted August 28, 2008 Author Posted August 28, 2008 On the 7 pin HD, are all pins used?????? I guess I need to find the H-D pinout....
Tombo Posted August 29, 2008 Posted August 29, 2008 I have an 07 RSV and 2003 Ultra Classic H-D. I have the J&M headsets and just bought the separate patch cord for each bike. Ride on.... Tombo
lonestarmedic Posted August 29, 2008 Posted August 29, 2008 In about 1998 Harley went from 5 pins to 7 pins. The 1st Gen Venture, 2nd Gen Venture, older HD, and Goldwings up to a certain year all use a common 5 pin. Some have a shrouded connector. I know my friends 1500 wing fits my 1st Gen. Ask WildHair to be sure, but I think Kaw's are similar. I have seen a 7-5 adapter. Note sure what feature you lose going from 5-7. They do make use of the pins. JB
KiteSquid Posted August 29, 2008 Author Posted August 29, 2008 (edited) I found the pin-outs...... The RSV pin-out from the top page of the Dlphifourms: http://members.cox.net/toma2/images/Audio.gif This is the H-D pin-out from the web: Ultra Headset DIN Plug Pin-out: Looking at the 7-pin connector with the index groove in the connector at the twelve o'clock position, the bottom pin is #2. So clockwise from the index groove the pins are #6, #1, #4, #2, #5, #3, #7. 6 is the shield/ground (one o'clock position) 1 is the microphone input (three o'clock position) 4 is the microphone ground (five o'clock position) 2 is the speaker ground (six o'clock position) 5 is the left speaker positive (seven o'clock position) 3 is the right speaker positive (nine o'clock position) 7 is the handheld PTT (eleven o'clock position) The shells for the 5 and 7 pin DIN are the same and the first 5 pins are in the same locations, SO the differences are the added pins 6 and 7 which are Shield and Handheld PTT. I don't need a handheld PTT, and the Shield might be needed in a high Electromagnetic Interference (EMI) environment, but we can probably dispenser with it, even though the coiled headset cord would be more susceptible to EMI than a straight cord. Could somebody please plug a 5 pin DIN corded headset into their H-D to test it? I don't have a headset, or a H-D with a CB handy... Edited August 29, 2008 by KiteSquid
Guest MikeH386 Posted August 29, 2008 Posted August 29, 2008 When I got my '07 Ultra I used my helmet w/mic & headset from my '89 VR. I could listen to the radio & CD but not talk with the the intercom. All I did was get a new lower cord from J & M and everything works great. The folks at J & M are really good. I sent an e-mail info request and had a reply the next morning.
KiteSquid Posted August 29, 2008 Author Posted August 29, 2008 When I got my '07 Ultra I used my helmet w/mic & headset from my '89 VR. I could listen to the radio & CD but not talk with the the intercom. Did it work for talking on the CB?????? Can you try it?????
Guest MikeH386 Posted September 3, 2008 Posted September 3, 2008 With the Yamaha 5-pin cord, the mic does not work. The intercom and CB use the same PTT (Push To Talk) circut.
