Gearhead Posted August 25, 2008 Posted August 25, 2008 Hi y'all, When I pulled the rear wheel on my Venture the inner race of the needle bearing on the LH side fell out, exposing the needles. I want to clean up the bearing and put in fresh grease. However, I can't get the needle bearing and its cup (outer race) out of the wheel without damaging it. Any ideas on how to clean the bearing while installed in the wheel? I wonder why Yamaha elected to use a needle bearing there instead of a sealed ball bearing like on the other side? The rear wheel on my Virago has no needle bearing. Seems like a strange solution. Jeremy
Squeeze Posted August 25, 2008 Posted August 25, 2008 The Needle Bearing is a better Idea for heavier Load. You won't get that outer Bearing out without damaging it. But since the Needles did fall out, you need to replace it anyway. The one you got is Junk. Definately. There's no aftermarket Part for this. This is a Yammi Part. I'm sorry to say this, but at least you can replace the Ball Bearing on the other Side with an Aftermarket Bearing.
okscooter Posted August 25, 2008 Posted August 25, 2008 Should look like this: [ATTACH]21178[/ATTACH]
MiCarl Posted August 25, 2008 Posted August 25, 2008 If you replace the bearing there are 2 separate parts. The bearing and the "collar" which is the inner race (shown next to the bearing in okscooter's photo). Don't forget the oil seal.
Gearhead Posted August 26, 2008 Author Posted August 26, 2008 Well, this bike is a heavy load! Actually the needles didn't fall out, just the inner race or "collar". The needles are captive in a cage. I could simply slide the collar back in and go, there's no evidence of bearing damage. I just figure while I'm in there I want to clean it out and repack the grease. Thus the challenge - how to effectively clean the outer race - needle - cage assembly while in the wheel hub. Jeremy
Steve S Posted August 26, 2008 Posted August 26, 2008 If the needles look to be in good shape, just use a clean, lint free cloth to wipe any trash from the surface of the bearings. If you have a needle attachment for your grease gun you can use it to inject grease into the bearing. If not, just put some grease on your finger and push it into the bearings. You will be surprised at how little grease these bearings actually require. Good luck.
mm482 Posted August 27, 2008 Posted August 27, 2008 I washed the bearing out with a can of spray carburetor cleaner. I let it dry and then I repacked it with wheel bearing grease. Earl
