When I start the Venture and switch on the cruise control for the first time it always works flawlessly. If I then cancel it and try to resume speed it works sometimes and not every time. If I switch off the cruise control and turn it back on again it usually won't set.
Is there anything that I can do to make it work more consistently?
  • 3 weeks later...
The problem is usually related to the clutch switch. Sometimes I have to intentionally push the clutch out and take up the slack.
It was giving me problems yesterday as well. I put a bit of silicone in the switch slider, and now it's OK again.
