Guest tessa c2
okay what is the quickest way to jerk this U joint out on the 86's which is located under the rubber boot on the forend of the drive shaft? :scratchchin:
Take the Wheel out
remove the Final Drive
undo the Shock Connection to the the Linkage
undo Shock Linkage
undo Swingarm
undo Rubber Boot
open the thee Bolts on rear left of the Casing
undo three Bolts around the U-Joint
pull the Unit out of the Casing
place Unit in a Vise
undo the C-Clips on the Cross of the U-Joint
undo the rear Half of the U-Joint
open Nut on the front Half of the U-Joint
undo U-Joint
Guest tessa c2
okay so that pinion gear comes out, then work on the universal joint, know one thing for sure there is going to be a few achore bolts put in the floor of the shop. it's to tough on the constitution, having the bike balanced on the bike jack, thanks for the tips, pete
You can do it sitting on the centre stand, where the front tire can be on the floor, as well. :2cents:
Guest tessa c2
yup that is where she is now, but i just needed some height to get the rear wheel out from under the bags, should have her together this weekend yet, got crappy work hours this weekend but will have her ready for the P I P:thumbsup2:
