Guest tessa c2 Posted August 21, 2008 Posted August 21, 2008 okay what is the quickest way to jerk this U joint out on the 86's which is located under the rubber boot on the forend of the drive shaft?
Squeeze Posted August 21, 2008 Posted August 21, 2008 Take the Wheel out remove the Final Drive undo the Shock Connection to the the Linkage undo Shock Linkage undo Swingarm undo Rubber Boot open the thee Bolts on rear left of the Casing undo three Bolts around the U-Joint pull the Unit out of the Casing place Unit in a Vise undo the C-Clips on the Cross of the U-Joint undo the rear Half of the U-Joint open Nut on the front Half of the U-Joint undo U-Joint
Guest tessa c2 Posted August 21, 2008 Posted August 21, 2008 okay so that pinion gear comes out, then work on the universal joint, know one thing for sure there is going to be a few achore bolts put in the floor of the shop. it's to tough on the constitution, having the bike balanced on the bike jack, thanks for the tips, pete
Rocket Posted August 21, 2008 Posted August 21, 2008 okay so that pinion gear comes out, then work on the universal joint, know one thing for sure there is going to be a few achore bolts put in the floor of the shop. it's to tough on the constitution, having the bike balanced on the bike jack, thanks for the tips, pete You can do it sitting on the centre stand, where the front tire can be on the floor, as well.
Guest tessa c2 Posted August 23, 2008 Posted August 23, 2008 yup that is where she is now, but i just needed some height to get the rear wheel out from under the bags, should have her together this weekend yet, got crappy work hours this weekend but will have her ready for the P I P:thumbsup2:
