Eugene Posted August 17, 2008 #1 Posted August 17, 2008 Hello all - I did a quick search/read but am still a bit unsure. Are there risers available for a 2006 RSTD?
Everette Posted August 17, 2008 #2 Posted August 17, 2008 My understanding is there is not a set of risers for the RSTD. I think it interfers with the speedometer. You would probably have to change the bars.
Eugene Posted August 18, 2008 Author #3 Posted August 18, 2008 That's what I inferred - thanks Everete.
SteveP Posted August 18, 2008 #4 Posted August 18, 2008 You can add Baron's 1.5" Riser Extensions: http://www.baronscustom.com/catalog/display/777/index.html Many here have them. They did the trick for me: no more sharp pain between the shoulder blades after long rides. The risers will come into contact with the black plastic piece around the ignition key hole, but no damage (if you have the chrome cover, I understand that the chrome will crack). It's an easy install, but is nice to have a friend there to tighten the bolts while you hold the bars in position. Of course, a pad or a few towels on the tank to prevent unsightly accidental dings should the bars slip when loosened. There is plenty of slack in the stock cables to install the Baron's extensions.
SteveP Posted August 18, 2008 #5 Posted August 18, 2008 OK... Maybe I should READ the post before I chime in... RSTD is not the same as RSV. sorry
Eck Posted August 18, 2008 #6 Posted August 18, 2008 SteveP said: OK... Maybe I should READ the post before I chime in... RSTD is not the same as RSV. sorry They have them for the RSV also....and handle bar riser will hit the switch cover but barely touching it..
Eugene Posted August 19, 2008 Author #7 Posted August 19, 2008 Hi Eck - do you mean they have them for the RSTD also? Or the RSV? Steve thanks for trying - Eugene
