donaldj2242 Posted August 16, 2008 #1 Posted August 16, 2008 Just turn 20,000 miles on my 2005 RSV and decided to check the brake pads. Front pads looked new but rear pads were gone. My question is, are the front and rear brake linked and no front brake being applied, or am I just using to much rear brake???
Freebird Posted August 16, 2008 #2 Posted August 16, 2008 I think it's pretty common for the rear pads to go first. That's been my experience anyway and I do NOT use the rear that heavily. Maybe because there is only one set of pads rather than 2 sets as on the front. I'm not sure. Also, I always tell folks to check the INNER pad on the rear. I've a LOT of times when a quick inspection of the outer pad will lead an owner to assume that the pads are good only to find that the inner pad is completely worn out. Shouldn't be that way but I've seen it many times.
2WHEELSFORME Posted August 16, 2008 #4 Posted August 16, 2008 My Venture eats rear pads like no other bike I've known.
Steve S Posted August 16, 2008 #5 Posted August 16, 2008 Donald. I noticed the same thing as you. My first two sets of rear pads went real quick so when I replaced the front pads, I switched to EBC-HH pads. I am getting better braking power plus a lot more wear out of them. However, my next set for the rear will not be HH. They have too much bite. That was the cause of my accident in November 07. I was scuffing off some speed with my rear brake when I hit a bump and locked the rear wheel up. Now the only time I use the rears are to hold the driveshaft tight while I keep the RPMs up in a tight curve. The rest of the time it's front wheel or engine braking. Hope this answers your questions.
Riderinthesnow Posted August 17, 2008 #6 Posted August 17, 2008 Install FRONT pads from first generation Venture on the rear brakes. Pads last much longer.
Gambler Posted August 17, 2008 #7 Posted August 17, 2008 Aseguier Have U put pads from First Gen on back of 2nd Gen, How many miles U got on them Gambler
