Guest Ky Hammer Posted August 12, 2008 #1 Posted August 12, 2008 I am looking to put 4 way flashers on my 06 RSTD but can not find them. Anybody have any ideas where I can get them? Thanks!
Squidley Posted August 12, 2008 #2 Posted August 12, 2008 This may be a dumb question on my part, but the Ventures have them on the right side bar cluster by the starter switch. Do the RSTD's have them there, and it might have been overlooked
Lone Eagle Posted August 12, 2008 #3 Posted August 12, 2008 Squid, to the best of my knowledge, they don't. They put the cruise control switches there instead.
Guest cwil2988 Posted August 12, 2008 #4 Posted August 12, 2008 My 06 RSTD doesn't have flashers on it either, and a friend's road star doesn't either.
spyderhead Posted August 12, 2008 #5 Posted August 12, 2008 My 05 RSTD doesn't have them either; sure wish it did.
Squidley Posted August 12, 2008 #6 Posted August 12, 2008 Squid, to the best of my knowledge, they don't. They put the cruise control switches there instead. Now I know, thanks for the info Vic...who says an old dog can't learn new tricks
Johnh Posted August 13, 2008 #7 Posted August 13, 2008 You can wire in a flasher through a single throw two circuit toggle switch and feed it to the wires for the two rear turn signals. Everything will fit under the seat, and you can mount the toggle switch through one of the side covers. I hope this helps.
SteveP Posted August 14, 2008 #8 Posted August 14, 2008 Take a look at the Kisan signalMinder. I added it to my Suzuki Volusia, mainly for turn signal cancellation & running lights, but it has the added benefits of 4-way flashers and escort mode flashers (alternating left-right turn signals). It utilizes the stock turn signal switch for the flasher features: four consecutive on/off lefts for 4-ways, rights for alternating.
guns_usn_20 Posted August 14, 2008 #9 Posted August 14, 2008 (edited) Steve, WHAT MODEL OF SIGNAL MINDER DID YOU HAVE TO GET? the kisan web site dosen't list one for the 07 RSTD that I can find Jim Bell Edited August 14, 2008 by guns_usn_20
SteveP Posted August 14, 2008 #10 Posted August 14, 2008 (edited) Jim: I purchased the SM-3SV, but that was for Suzuki Volusia. It was a splice-in model. They probably don't list one for the RSV or RSTD because these bikes have turn signal cancellation already. I would look at the SM-4 (if the plug matches) or possible the SM-3SV (splice-in), but it would take some fiddling, I'm sure. My initial thoughts would be that you could set the ts cancellation on the signalMinder to the longest setting so it would not interfere with the built-in ts cancellation already on the bike -- the bike would cancel them before the SM module's time ticked away. Then you'd only be using the SM module for running lights (if you hooked that up) and flashers. I'm not sure that it would work as I have not done it on the Yamaha myself, but I don't see why not. This is all just my Edited August 14, 2008 by SteveP added URLs
jemorrisonjr Posted December 16, 2008 #11 Posted December 16, 2008 I found this on the Royal star riders site.... http://roadstarclinic.com/content/view/13/103
hcdagen Posted January 3, 2009 #12 Posted January 3, 2009 The Road Star Clinic article is excelent.One change I would suggest is to put the switch on the center panel instead of the side panel.That way when u remove the side panel u don't have to contend with the wires.There is a nice empty space just under the fuel pump for the switch and flasher.[at least on a RSTD].Herb
guns_usn_20 Posted July 18, 2012 #13 Posted July 18, 2012 A friend of mine has these on his KZ1000 Police bike he got the white strobes I have ordered amber ones. 1 link below. on youtube. you can search the other on E Bay 4 X 3 LED 12V Amber Car Police Strobe Flash Light Emergency 3 Flashing Modes Watch the youtube video first. the strobes are less than $15.00 w/shipping. I have amber lights coming. Jim
3pettz Posted July 21, 2012 #14 Posted July 21, 2012 I installed the KRISS Ind. four ways on my 05 RSTD. Installation was stright foward and I also used a chrome handle bar switch ( 2 push bottons) to turn them on and off. The secod switch is for my highway lights. Ill post some photos if you like, just let me know. Here is the link to KRISS Ind. http://www.kriss.com/
Phoneman1981 Posted July 21, 2012 #15 Posted July 21, 2012 Good Morning Everyone: Lone Eagle is correct. RSTD's do not have 4 way flashers like the RSV's. I too would like to add emergency flashers to my 05 RSTD. The information listed here is wonderful. I am going to check it out. Thanks:)
guns_usn_20 Posted July 23, 2012 #16 Posted July 23, 2012 I found this on the Royal star riders site.... http://roadstarclinic.com/content/view/13/103 If you are going to wire into the turn signal's you should put 2 diodes in line. this is so if you turn on the turn signals and the flashers are on the current will not go into the Flasher circuit. I went with the Amber strobes on Ebay, 3 modes to choose from.A frient has the white strobes on his KZ 1000 Police bike. they are sweet. Jim
3pettz Posted August 6, 2012 #17 Posted August 6, 2012 (edited) Attached you will find the pics I promised. Sorry it took so long! The first is of the location which is under the seat. Next to the unit is the relay that need to be installed next to it to power the unit. The second pic is of the switch on the right handle bar. the top button activates my highway lights the bottom for the flashers. If you decide to follow this configuration i will add the info if requested. Just give me some time to get my notes together...sorry about the lack of pics, I'm not sure what happen. Ill text them to you and try again to post later. Edited August 6, 2012 by 3pettz No pics!
