Silver Dollar Posted August 7, 2008 #1 Posted August 7, 2008 Greetings, while on vacation this past week, I discovered that the dash lights on my '05 RSV don't work. I'm speaking of the back-light that illuminates the speedometer. When dark, I cant see the speed or the gas gauge. Makes for some nerve racking riding. The last night ride prior was about a month ago, and it worked then. The only thing that has been done is the bike has been washed twice since then. Any ideas as to why it quit working? Are there regular bulbs or some type of LED lights there? Is this something that maybe I can fix, or do you recommend the dealer? Would this be a warranty item? Thanks in advance for any help.
royalstarjac Posted August 7, 2008 #2 Posted August 7, 2008 Yes it should be a warranty item. It might be that your ignition switch is starting to go out. Check all of your other lights and your fuses.-Jack
V7Goose Posted August 7, 2008 #3 Posted August 7, 2008 The dash back lights are not replaceable. Take it to the dealer to have it fixed under your 5 yr warranty. Goose
rod Posted August 7, 2008 #4 Posted August 7, 2008 Just a heads up. When I took my MM in for the gas gage not working They replaced the control board and that reset the odo to 0. I wish I had written the exact mileage down. Don't know if the light is on the same circuit board but better safe than sorry.
V7Goose Posted August 8, 2008 #5 Posted August 8, 2008 rod said: Just a heads up. When I took my MM in for the gas gage not working They replaced the control board and that reset the odo to 0. I wish I had written the exact mileage down. Don't know if the light is on the same circuit board but better safe than sorry. Go back to that dealer and have them pull up the shop ticket. They have to record the mileage before they start work, and for warranty work, I think it needs to be reported to Yamahaha too. Anyway, they will have the exact mileage when they replaced they instrument head. Goose
CTrider Posted August 18, 2008 #6 Posted August 18, 2008 How did you make out with the dash lights? tx in advance
Silver Dollar Posted August 18, 2008 Author #7 Posted August 18, 2008 CTrider said: How did you make out with the dash lights? tx in advance I haven't had time to get it to the dealer yet. I drive a truck, and had to play catch-up after vacation. I hope to get it there friday. I will post the results.
