Does your shock have seal on the botton .I found some oil on the botton of it there was a small puddle under the bike were it is:icon_smile_question
Your shock is bad. Not a cheap fix. Stock shock is close to $400, and the only aftermarket item is about $650 (Works Performance shock). If you plan on putting more than another 20,000 miles on the bike, you are better off with the Works Performance item. :080402gudl_prv:
Goose
