FozzyUSN Posted August 5, 2008 #1 Posted August 5, 2008 If my bike sets for over a 24 hour period, the memory presets are erased. Does anyone know why this would happen? The radio works just fine and I can reset the memory presets. Thanks ahead for any input.
rod Posted August 5, 2008 #2 Posted August 5, 2008 Your antique bike has alzhimers. :rotf::stickpoke:Sorry could not resist Rod
Bummer Posted August 5, 2008 #3 Posted August 5, 2008 Battery getting old? (Just a guess, not a wise crack. Though I suppose it could go both ways.)
az1103 Posted August 5, 2008 #4 Posted August 5, 2008 (edited) Clean your battery connectors ! I had the exact same problem on two of my cars. Cleaned the battery posts greased the connection, problem gone. Edited August 5, 2008 by az1103
rod Posted August 5, 2008 #5 Posted August 5, 2008 Ok seriously you should have 2 power leads to the radio one for the memory one for the radio it self. Look at the connections for corrosion. Rod
rez Posted August 5, 2008 #6 Posted August 5, 2008 Don't forget to check the 'Back-Up' fuse. (for memory). I believe it's 5A. I just recently had to replace mine.
