Don't break the rear resevoir
This is a repeat of a reply I offered to a sad soul and thought it to be important enough to post a new thread so that everyone might benefit.
This doesn't have to happen. Support the flat sided filler spout with a 16mm open wrench and turn against the 16 with a 14mm on the plug's hex head. That way you are neutralizing the stress placed on the thin sides of the pot metal fluid reservoir. Replace the plug with a brass or nylon washer and just snug it down. End of story.
On the 1st gens, the rear brake reservoir is mounted above the master cylinder. It has a 14mm fill bolt located right near the corner of the unit. He is describing a good way to remove this bolt without breaking the reservoir.
Dan
