bongobobny Posted August 4, 2008 #1 Posted August 4, 2008 I encountered a really strange one on the road Saturday. We stopped for ggas and when I went to restart, it acted like my battery took a dump. We push started ok, but the voltmeter barely made it up to 12 volts. About a half hour down the road I just happened to notice that my Hi/Low beam switch was halfway inbetween the 2 settings, so I reset it. Almost immediately the voltmeter went up above 12 volts, and the problem was solved. Fine and dandy, but yesterday I smelled a very faint burnt electrical smell, and looked, and sure enough the darnn switch was halfway inbetween again, same basic symptom. Put switch back and everything is beautiful again. I may be accidently hitting the switch when clutching as we have been doing a lot of twisties these last 2 days... Just wanted to make you aware of a potential problem source!
Dano Posted August 4, 2008 #3 Posted August 4, 2008 Hmmm, looks like "kill switch syndrome" is starting to affect the left handlebar now. Man this illness is traveling quick!! I hope a cure is found someday!!!! Dan
GeorgeS Posted August 4, 2008 #4 Posted August 4, 2008 You might want to open up the assembly, and check the Mechanical condition of that switch. ( you mentioned a burnt smell ) Possible High resistance Condition across the Switch Contacts. You might find some Burned contacts in that switch!!
Dano Posted August 4, 2008 #5 Posted August 4, 2008 What gets me George, is he's saying that the switch is inbetween the positions. I would think that possibly the spring is bad or it's just worn out. Probably has both elements lit up, thats why the volts are dropping. Just like having too many lights on. I would be leary of the switch, tho. Dan
GeorgeS Posted August 4, 2008 #6 Posted August 4, 2008 What gets me George, is he's saying that the switch is inbetween the positions. I would think that possibly the spring is bad or it's just worn out. Probably has both elements lit up, thats why the volts are dropping. Just like having too many lights on. I would be leary of the switch, tho. Dan Yes: I think a Switch Replacement is deffinatly in order here. No sence takeing a chance. Also, 12V on the meter sounds LOW. Should be OVER 13. ????? I smell a rat--- Time to get the Volt/Ohm meter out
Condor Posted August 4, 2008 #7 Posted August 4, 2008 Hmmm, looks like "kill switch syndrome" is starting to affect the left handlebar now. Man this illness is traveling quick!! I hope a cure is found someday!!!! Dan The cure exists.... Use the switch every time you turn off the engine. Keeps the contacts clean and corrosion free. You know what they say. "Use it or Lose It"
Gearhead Posted August 4, 2008 #8 Posted August 4, 2008 What gets me George, is he's saying that the switch is inbetween the positions. I would think that possibly the spring is bad or it's just worn out. Probably has both elements lit up, thats why the volts are dropping. Just like having too many lights on. Yeah, agreed, but the alternator should handle an extra 55W without dropping to 12V. My bike has a pair of 55W driving lights (extra 110W) and it just barely handles it. I'm not saying it's normal or good to run with both headlight elements lit, but that should not kill the voltage if the engine is running a few rpm's. Jeremy
GeorgeS Posted August 4, 2008 #9 Posted August 4, 2008 I still say, Replace the Switch, But being an Electrician, thats what I always do !! I never met and Electronic, electrical component that I trusted !!!
86er Posted August 5, 2008 #10 Posted August 5, 2008 A lot of times on my '86, in really dark areas or twisties at night, I'll run with the switch in that position and I've never had a problem or had much of a drop in the voltage. Of course the volt meter on these bikes isn't the most trust worthy! I do like the extra light!
OMG Posted August 5, 2008 #11 Posted August 5, 2008 Wow, interesting responses, guys!! This mis bongobob on mother's computer. Found the switch in the same condition a couple of times today. Maybe too many twisties!! I will disassemble and clean the switch when we get back...
bongobobny Posted August 6, 2008 Author #12 Posted August 6, 2008 OK I think I finally figured it out. I think putting the helmet on ther Garmin mount at the rest stops was putting that switch in that position...
