Ken Parker Posted August 3, 2008 Posted August 3, 2008 I hope this doesn't sound too stupid, here goes, I need to change the plugs in my 2005 RSV. 10k mles the 2 in the back seem to be fairly easy to reach . My question is the 2 front plugs. Do you remove the brace (not sure what is called) that prevents access to these plugs? And if so what problems can that lead to. Also what plugs do you guys recommend? Thanks
V7Goose Posted August 3, 2008 Posted August 3, 2008 Yup, you need to remove the tank and front dog bone engine mounts to get to the front plugs. Not hard to do at all. I just use stock NGK plugs; wouldn't waste my money on anything "fancier." Goose
gunboat Posted August 4, 2008 Posted August 4, 2008 hi ken yep just like goose said, the only think i would add is to use a 3/8 rachet with the metric allen head type sockets. to get to the allen head bolts, you can use the regular type allen wrenches just seams easer to use the sockets. ( the allen head is about 1 to 2 inches sticking out of the holder socket ). you can find these at any auto store / sears tool department. just my 2-cents. best reguards don c.
Ken Parker Posted August 4, 2008 Author Posted August 4, 2008 Thanks for the input guys looks like rain for a couple of days here in Houston so I think I'll tackle it Wednesday.
Eddie Fulmer Posted August 4, 2008 Posted August 4, 2008 My only question is do they really need changing after only 10K?? I'm not planning on changing mine until around 40K. What say the gurus here??
juggler Posted August 4, 2008 Posted August 4, 2008 Perfect timing. I'm about to do the same thing. I know Vgoose's thoughts on spark plugs, now what do others recommend for plug type?
juggler Posted August 4, 2008 Posted August 4, 2008 My only question is do they really need changing after only 10K?? I'm not planning on changing mine until around 40K. What say the gurus here?? The manual says replace the plugs every 8k miles. See page 7-3 of the owners manual.
2WHEELSFORME Posted August 4, 2008 Posted August 4, 2008 I'm at 33K and Im thinking about changing them because I do have a set on the bench. Also the bike is down for rear tire anyway.
wizard Posted August 4, 2008 Posted August 4, 2008 Change them at the recommended intervals. I believe that you'll notice a difference. I use the NGK plugs and have had no issues with em.
Rich99 Posted August 4, 2008 Posted August 4, 2008 Yup, you need to remove the tank and front dog bone engine mounts to get to the front plugs. Not hard to do at all. I just use stock NGK plugs; wouldn't waste my money on anything "fancier." Gooseand the stock plugs are NGK 4929's. Suppose to change every 8,000 miles untill your 5 year warranty is up. :080402gudl_prv:one more time.
V7Goose Posted August 4, 2008 Posted August 4, 2008 and the stock plugs are NGK 4929's. Suppose to change every 8,000 miles untill your 5 year warranty is up. :080402gudl_prv:one more time. Just for reference, the 4929 is the stock number on the NGK plugs - the actual reference number from the owner's manual is DPR8EA-9. Both numbers refer to the same plug. Goose
KeithR Posted August 4, 2008 Posted August 4, 2008 Ken Get yourself a short piece (6"-8") of 3/8" id hose. It will make it easier to thread in the new plugs. Keith
MAINEAC Posted August 5, 2008 Posted August 5, 2008 IMO the NGK Iridium plugs are worth the extra few $s... I've noticed a change in performance going both ways... For example Ok a change to new plugs some will say just changing to new will increase performance... Valid point... but last year in TX I thought I lost a plug and I had a bike shop swap my plugs and I was still on 3 cyls... It needed a coil.. they swapped the coil and when I got the bike back it didn't have the same zip because they used regular NGKs... I've been sold on Iridiums ever since.
