Hey guys. I know that this has been brought up before and I wanted to share with ya'll what I just found.
http://www.crutchfield.com/S-51I56E4bKZj/cgi-bin/ProdView.asp?g=51000&I=105CSBB2
dimensions: 11-5/8"W x 2-1/2"H x 7-7/8"D
It'd fit, I think, in a saddlebag, maybe in the trunk... would definately take up a bit of room, though...
It comes with a wired volume control.
Getting it to fit somewhere probably isn't much of a problem, but supplying it with enough amps to drive it might.....
Well Jack, the power draw would be about the same as low beam head light. Or less then a set of driveing lights.
I'm going to look into this, very interesting piece of equipment.
Is there any reason why an amp couldn't be rigged to a power switch like the driving lights, though so there isn't a constant drain on the battery?
Yes , you can do that. Also, the amp is never drawing full power except when music is hitting high volume peaks.
The average power draw, is probably only about 20 percent of the full amplifer wattage rateing.
Also, if you were useing an Odyessy PC-680 Dry cell, deep cycle battery, I doubt there would be a problem.
  • 8 years later...
Wonder if your subwoofer would fit under either seat. At least you could feel the thing!
I thought about adding some speakers in trhe bottom fairings, but couldn't get comfortable with the spaces there. Just no room.
  • 3 months later...
I got the sub installed a few weeks ago- cant really hear it... but the good thing is it has a remote control for the volume so I can turn it down and up... Really have to open the trunk to hear it. But when the trunk is open it has a great sound. The unit in the link above was the one I installed- has a 2 channel amp that can power a set of speakers- so I used that on my fronts.
I was afraid of that. Seems like sort of a waste if you only here it with the trunk open. Oh well....this has been kicked around here for years and I've still never seen a great solution for improving the sound on these bikes. We use earbuds and that works great for us.
