Freebird Posted July 31, 2008 #1 Posted July 31, 2008 OK folks, I got an email from one of our members Michael F. Kerr. Michael lives in San Diego and is having a problem with is '83. Here is the message. His user name here is Michael F. Kerr so you can PM him at that name. My faithful "Black Beauty" is showing her age. She's an '83 gen 1. I've been plagued by an oil leak I finally traced to a leaking cam cover gasket. This was surprising, as the engine was just re-built a while back, and the cam cover seals were new. Long story short: As you know, each of the eight cam shaft hold down caps has a cast in, threaded, boss where the cover bolt threads in. On one cap, this boss is broken off, don't know why, although the aluminum isn't the best looking I've ever seen. A poor casting combined with age, I suspect. Another is stripped. I suspect it "popped" just as I let up on the torque wrench, and I missed it. Or maybe it was marginal, and heat expansion did the deed. So my question is: are you or any of the other riders aware of a Gen 1 engine being retired and "pieced out"? I looked at the online parts manual, and they, the caps, don't seem to appear as a seperate part...probably because the cam bore would have been line bored at the factory with the caps in place when the engine was built. So maybe someone knows of some laying around? If I can find a few I can get them sized here, and I've found very good steel inserts to re-thread all the existing 6mm holes.
muffinman Posted August 1, 2008 #2 Posted August 1, 2008 Don I will take care of this if a 1300 part will work thanks for posting this. Jeff
cmiles3 Posted August 1, 2008 #3 Posted August 1, 2008 I have one, but I'll be gone for 3 weeks. If you don't get one before I get back, send me a note- should be home about Aug 25.
Freebird Posted August 1, 2008 Author #4 Posted August 1, 2008 Folks, it's not for me. Michael said that he isn't real savvy about posting so I posted it for him. Here is a link to his profile, please contact him if you can help. http://www.venturerider.org/forum/member.php?u=2640
