Guest pkksr Posted July 27, 2008 Share #1 Posted July 27, 2008 I am looking at replacing the stock turn signals on my 07RSV. Any suggestions? Link to comment Share on other sites More sharing options...
KiteSquid Posted July 27, 2008 Share #2 Posted July 27, 2008 Get some 2357A bulbs from the autoparts store and cut off one of the pins. You wil have to look at your factory bulb to tell which one to cut off. The 2357LL bubls work GREAT in the stop lamp!!!! Inexpensive and quite a bit brighter. Link to comment Share on other sites More sharing options...
Bummer Posted July 27, 2008 Share #3 Posted July 27, 2008 Squidley asked me about my turn signals at Kitchener. This is where I got 'em. They're VERY bright, and the Eclipze version for the front is pretty cool. You can get the three pin bases for the newer fronts. I had to run a file around the outside once or twice to get a perfect slip in fit. I didn't use a load equalizer. They flash a little fast, but no faster than if there were one burnt out, which doesn't bother me at all. Might even make 'em more noticeable. Link to comment Share on other sites More sharing options...
Guest pkksr Posted July 27, 2008 Share #4 Posted July 27, 2008 Thanks, I will check them out. Looks like the wiring is the same as stock, you just needed to file to fit in the stock signal?? Thanks Link to comment Share on other sites More sharing options...
Bummer Posted July 27, 2008 Share #5 Posted July 27, 2008 (edited) The aluminum/fiber plates were the tiniest bit too big to just slip in on two of them. A light swipe or two with a file around the outside edge slipped 'em right in, good and snug. They fill the entire bezel opening. The pigtails plug right in to the sockets. Remember that the newer bikes ('05 and newer, I think) are three pin in the front. Here's a pic showing the difference between stock and the LEDs. The brakes are not on. The tail light is a 128 LED board by RadiantZ. Right now I'm trying to figure out how to change the wing lights to ultra bright LEDs too. Edited July 28, 2008 by Bummer Added the pic Link to comment Share on other sites More sharing options...
