I have an old Motocomm headset that I used on my V-star connected to a small CB. Does anyone know if I can get an interface connection cable to hook up between that and the 5 pin Yamaha connector?
I will eventually go for a J&M set but for now I'd like to use the existing headset I have.
Any info is appreciated.
Guest gitarzan
I've that same JM set. No complaints, esp. for that price.
  • 6 months later...
Guest r-retzke
An Autocom headset can work with the Venture and similar DIN 180º 5-pin systems. This attachment shows how.
Rog in NH
[ATTACH]13285[/ATTACH]
  • 5 months later...
Guest Kurt Leopold
where can I find who sells the edsets I see mentioned?
I have that setup on my Vstar 1300 and I tried to swap speakers for better sound quality and found out that my J&M had 3 wire speakers vs 2 wire for the MotoCom. setup, I also tried a converter plug, that didnt work either, They must use a different wiring for the mike and speakers than the J&M, if you do succede, please let me know, I havent been able to find anything, so I have to have 2 helmets with different headsets, 1 for each bike. Good Luck.
