Guest cwil2988 Posted July 23, 2008 #1 Posted July 23, 2008 Anyone ever tryto sync the carbs using only one vacuum gauge? seems like it would be possible, just time consuming.
Leland Posted July 23, 2008 #2 Posted July 23, 2008 You are not really interested in what the exact vacuum is, only that they all read the same.
Squeeze Posted July 24, 2008 #3 Posted July 24, 2008 you can't do that, you need at least 2 Gauges to compare Vacuums
SilvrT Posted July 24, 2008 #4 Posted July 24, 2008 you can't do that, you need at least 2 Gauges to compare Vacuums I did it on my Honda 500-4 with one gauge... took quite a while as I recall but I did it.
Squeeze Posted July 24, 2008 #5 Posted July 24, 2008 I did it on my Honda 500-4 with one gauge... took quite a while as I recall but I did it. and how did you double check the Outcome ? I guess 'a while' is the Time it takes to Motor to cool down twice ....
