SilvrT Posted April 19, 2007 Posted April 19, 2007 Bike has been parked all winter. Discovered that the rear tire was almost flat (yet it was around 45lbs when I parked it). Checked the tire and noticed a piece of metal like a nail embedded into the tread. Haven't tested for a leak yet but will later tonight. No idea how long it might have been there but recall air pressure dropping about 10lbs over a 2 month time span last summer. The tire is good and is a Avon Venom-X so I really don't want to replace it yet. Can such a thing be fixed? We used to (and probably still do) put plugs in car tires. Can this be done on a m/c tire or what?
Black Ice Posted April 19, 2007 Posted April 19, 2007 Rick, scroll down to the Similar Threads listed below and take a look at the postings under the one titled "that old nail in the.....". It should help you. Good luck!
BuddyRich Posted April 19, 2007 Posted April 19, 2007 I have run several tires with plugs in them. Had a ME880 once with 3 in it. Rode them till they had to be replaced due to lack of tread.
SilvrT Posted April 19, 2007 Author Posted April 19, 2007 Rick, scroll down to the Similar Threads listed below and take a look at the postings under the one titled "that old nail in the.....". It should help you. Good luck! That's good info...thanks a bunch. The general consensus appears to be that it's ok to plug the tire and that Ride-On is a good product. I think I'll go with those solutions.
Black Ice Posted April 19, 2007 Posted April 19, 2007 Ya, I'd do it. I get my tires from a local fellow who only works on bikes and he patches all the time if its a clean hole and not in the side wall. Cheers
SilvrT Posted April 19, 2007 Author Posted April 19, 2007 Rick you got mail. :canada: I do? where? (there's nothing showing up top here)
StuD Posted April 19, 2007 Posted April 19, 2007 I do? where? (there's nothing showing up top here) E Mail:rotf: :rotf: :canada:
SilvrT Posted April 19, 2007 Author Posted April 19, 2007 E Mail:rotf: :rotf: :canada: I guessed that ya nut! ... when I went and looked, there was nothing...I just went and looked again and found YOUR email in my JUNK MAIL !!! :sign20: :sign20: :sign20:
