pegscraper Posted April 18, 2007 Posted April 18, 2007 What's the recommendation on how many miles to run between tire rotations front to back, you know, like we do on cars? Y'all do rotate your tires front to back periodically, don't you?
calperin Posted April 18, 2007 Posted April 18, 2007 Only left to right. never cross left rear to front right. :rotf: :rotf: :rotf:
Marcarl Posted April 18, 2007 Posted April 18, 2007 I rotate them every time I go for a ride, that way I don't forget to do it and have much more piece of mind while on the road. For me it's always saftey first, so I check to make sure that one time the stem is on top and the next it's on the bottom, just can't remember if it was on the top or bottom when I parked it last fall, darn does that mean I now have to get new rubbers? wonder what my wife will say about that,,,,,, I'm just getting a little older maybe?
RSTDinPA Posted April 18, 2007 Posted April 18, 2007 What's the recommendation on how many miles to run between tire rotations front to back, you know, like we do on cars? Y'all do rotate your tires front to back periodically, don't you? My tires rotate constantly when I am riding...front and rear.
FreezyRider Posted April 18, 2007 Posted April 18, 2007 And since we're talking about tires and safety, y'all don't forget to get that winter air out of your tires and get it replaced with summer air. I usually make sure mine is changed by the end of April, then change back to winter air in November. Of course, those of you in warmer climates may do it differently. What's your schedule???
gibvel Posted April 18, 2007 Posted April 18, 2007 And since we're talking about tires and safety, y'all don't forget to get that winter air out of your tires and get it replaced with summer air. I usually make sure mine is changed by the end of April, then change back to winter air in November. Of course, those of you in warmer climates may do it differently. What's your schedule??? Air? Who uses air? I use Helium. Makes the bike far lighter and way easier to handle!!
RedRider Posted April 18, 2007 Posted April 18, 2007 Rather than rotate tires, I just run in reverse for the second half of the riding season. RR
Squeeze Posted April 18, 2007 Posted April 18, 2007 Rather than rotate tires, I just run in reverse for the second half of the riding season. RR which also give's you back the worn Tyres .... :D
Squeeze Posted April 18, 2007 Posted April 18, 2007 Air? Who uses air? I use Helium. Makes the bike far lighter and way easier to handle!! you might know it but nevertheless ... if using Helium, you should check and refill the Tyres at least every Week.
gibvel Posted April 18, 2007 Posted April 18, 2007 you might know it but nevertheless ... if using Helium, you should check and refill the Tyres at least every Week. It was a joke.
Venturing Sole Posted April 18, 2007 Posted April 18, 2007 ...and of course you have to rotate the spare in the trunk so it gets some use too.
Squeeze Posted April 18, 2007 Posted April 18, 2007 It was a joke. i did understand the Sense of your Words :D , but my quote wasn't a Joke either ... :D ....
Saddle_Bag Posted April 18, 2007 Posted April 18, 2007 I don't rotate anymore, putting the studded winter tire on the front cuts down on the milage.
BuddyRich Posted April 18, 2007 Posted April 18, 2007 I always just take them off and point the arrows the other way when I put them back on.
Condor Posted April 18, 2007 Posted April 18, 2007 What's the recommendation on how many miles to run between tire rotations front to back, you know, like we do on cars? Y'all do rotate your tires front to back periodically, don't you? 'Bout every 3000 miles. Really helps the cornering in reverse....
dray Posted April 18, 2007 Posted April 18, 2007 Air? Who uses air? I use Helium. Makes the bike far lighter and way easier to handle!! dont this make the bike more top heavy adding helium to the tires seems like it would want to flip upside down or you could go out in the garage in the morning and find the bike on the celing:whistling:
