lonestarmedic Posted July 16, 2008 #1 Posted July 16, 2008 I picked up a rear rim to have cleaned and powdercoated. As I examine the hub area I see the dampers where the lugs fasten. As the powdercoat process heats up to 400 deg. F. I need to remove the dampers. Any tricks to this or is it a simple press out procedure. Also, is there a reinstall procedure or measurement? I would guess uneven installation would cause runout and wobbles. Also thinking that deteriorated rubber would cause the same problems. Just a thought on the decelleration wobble idea. JB
Squeeze Posted July 16, 2008 #2 Posted July 16, 2008 If you're talking about the Rubber Dampers which the 6 Fingers of the Drive Hub engage to, you need to push them out with a Shop Press. Reinstalling the same Way using Hairspray as a temporary Lubricant.
Gearhead Posted July 16, 2008 #3 Posted July 16, 2008 The hub is supported by its own bearing on the axle, is it not? If so, then I would not think the rubber dampers would affect runout. Jeremy
lonestarmedic Posted July 17, 2008 Author #4 Posted July 17, 2008 Squeeze - as the hub is closed in, is there enough room to press them into the hub cavity then fish the dampers out through the bearing hole? Or am I missing something that exposes the other side of the wheel? I agree that the dampers should not affect runout per say. But during accelleration or decelleration could worn or soft bushings cause a vibration? They seem to be intact and not too soft. Just thoughts at this point in the game. JB
Squeeze Posted July 17, 2008 #5 Posted July 17, 2008 I haven't done by myself, but i that's what i've heard. They will come out through the Bearing Path after removing the Needle Bearing and Spacer.
