Sideoftheroad Posted July 12, 2008 #1 Posted July 12, 2008 ...are not working. I know the one that is located by the rear right passenger peg, where is the other one located at? When I press the horn button, the horn is barely audible. Anyone heard of both of the stock horns going out?
SaltyDawg Posted July 12, 2008 #2 Posted July 12, 2008 ...are not working. I know the one that is located by the rear right passenger peg, where is the other one located at? When I press the horn button, the horn is barely audible. Anyone heard of both of the stock horns going out? More than likely you have to tweak the screw on the back of the horn. It will adjust the tone of the horn. I have heard of some horns stopping work and just needed the screw turned a little. The second horn I believe is located behind the left lower cowling. That's probably the one you are hearing it sounds muffled without the other one. Just take the horn off and you will see a screw on the back of it. Have someone hit the horn while you turn the screw.
Eck Posted July 13, 2008 #3 Posted July 13, 2008 Food for thought... I would check for "power" to / at the horns before I would go tweeking any screws.. just my 2 cents..
Sideoftheroad Posted July 13, 2008 Author #4 Posted July 13, 2008 Not the screws. How/where to check the power to the horn. Thanks.
shcook Posted July 14, 2008 #6 Posted July 14, 2008 I had the same problem - very weak stock horns. I pulled them off and tested them using #12 test leads straight to the battery of my truck. They worked great off the bike. So I tested the voltage to the horns while they were still off the bike - voltage was good - just a little less than the battery voltage. But when I put them back on the bike and tested voltage again - less than 10 volts. A problem in the wiring - too much voltage drop. So I re-wired some new exceptionaly load horns - using the existing horn circuit to operate a relay. Power to the horns using #12 wire w/fuse off the realy. Mounted the horns just behind the bottom fairing on each side. Now they work !!
RedRider Posted July 14, 2008 #7 Posted July 14, 2008 Since you are pulling the horns off and messing with them, it might be a good time to install a Stebel horn. Many good sources on the net (bikebandit, JC Whitney, etc.). Get the bracket from Carbon One (I think - check in classified) to make mounting easy. JJ
Sideoftheroad Posted July 16, 2008 Author #8 Posted July 16, 2008 checked both fuse boxes. All fuses are ok.
Semi-retired Posted July 17, 2008 #9 Posted July 17, 2008 You mean ALL the fuse boxes, don't you? Aren't there THREE on these suckers? I'd get hold of a wiring diagram and check every connection that has ANYTHING to do with the horns.......which is what I'm about to do for my (intermittent) passing lights. :-) Good luck Oh, and by the way, could someone please post the link to the online service manual for my friend and me? (had it but misplaced it.) Thanks! checked both fuse boxes. All fuses are ok.
KiteSquid Posted July 17, 2008 #10 Posted July 17, 2008 Oh, and by the way, could someone please post the link to the online service manual for my friend and me? (had it but misplaced it.) Thanks! On the left side of ALL the pages there is a link called: VR Tech Click it and then on: Second Gen and Royal Star Technical Library then on Guides, Parts Diagrams, Etc. Then on Download the Owners and Service Manuals OR just click HERE Be sure to thank juggler for making them available to us!!!!!!
Sideoftheroad Posted July 17, 2008 Author #11 Posted July 17, 2008 (edited) I thought there were only 2 fuse boxes. One behind the brake side, lower cowl and one behind the clutch side, side cover by the seat. Where is the 3rd one? I was really hoping for a paper copy of the service manual. I don't have a computer in the garage to look at the diagram. Would defeat the purpose to print out the manual from the download. Might as well buy it. Either way, it cost $$$ for ink and paper. Thanks. Edited July 17, 2008 by Sideoftheroad
VentureProf Posted July 18, 2008 #12 Posted July 18, 2008 I gave up on the stock horns 3 years ago (even though they still 'worked') and mounted electric Rivco's (keeping the stock horns in place). Mounted the chrome plastic Rivco's using the lower mounting bolt for the airboxes at the lower fairing (they tuck up just above and forward of your feet), and ran the needed wiring/relays etc. These are loud, protected from rain and road crud, and look great in that location. Couldn't be happier. Kelly
WRoger Posted July 21, 2008 #13 Posted July 21, 2008 ...are not working. I know the one that is located by the rear right passenger peg, where is the other one located at? When I press the horn button, the horn is barely audible. Anyone heard of both of the stock horns going out? I didn't see an answer posted for this (could have missed it), but the second horn is buried behind the left fairing. It's black plastic. My horns are pathetic; they sound like the last gasp of a dying calf in a hailstorm. The fairing one won't sound unless the engine is running (14 volts). I'm looking at air horns.
