gator37 Posted July 10, 2008 Posted July 10, 2008 I have a squeak in divetrain of 91 venture royale.It sounds like a squeak you get in u-joint of car,speeds up and slows with speed of bike. Someone indicated the is a auto ujoint the will replace the $100 yamaha part for much cheaper. Can anyone help with the part and/or suggests as to cause of noise if it wouldnt be u-joint? Thanx in advance
Eck Posted July 11, 2008 Posted July 11, 2008 Could be the lack of grease on rear hub pins, the drive shaft splines, possible worn wheel bearing and or swing arm bearings...lots of options to place the blame on.. If you tear it down to check one you may as well check / grease them all..
mm482 Posted July 11, 2008 Posted July 11, 2008 I think this is the info you need. Go to this page http://www.venturerider.org/forum/showthread.php?t=6238 Earl 86 VR 00 RSV
