Cdnlouie Posted July 3, 2008 #1 Posted July 3, 2008 Hey fellows, Just wondering if anyone might have experienced a rear wheel whine while leaning left at 80 Kmh (or 50mph)? It has been around for the last couple of years (at least 10,000 km) and I have not paid much attention to it. You can't really hear it below 80kmh or above 90kmh (55mph). It is just in that one speed zone and only when leaning left. Changing tire pressure does not seem to make any difference either. My gut feeling seems to think that the rear tire might the source of the sound. My Dunlop Elite II is about 40% worn and I can't remember if the sound was there when it was new or not. I am wondering if the cupping from wear is making it do this sound when leaned into the transition edge zone (Ie. between normal straight up running zone & the rarely used corner zone)? I can't remember if I read somewhere that the Firs Gen Venture rear wheel is slightly offset from the front (due to engine design, etc. - I could be wrong here) which could also accentuate the tire sound when leaning to one side more than the other. Another thought is that there may be a rear wheel bearing that might be showing some wear, but I don't have any experience with that on a Venture so I will have to throw it out to you all to see if you have had a similar experience . Thanks for looking, Dr. C.
Venturous Randy Posted July 3, 2008 #2 Posted July 3, 2008 Tires with any cupping at all will produce noise, and some do without cupping. One thing I would definately do if you have not done so far is to take the driveshaft out and make sure it is lubed real good on both ends. This is routine maintanence for these 83/85 bikes. The fact that it is more noticeable while leaning left is the sound may be being bounced off the ground more and you hearing it. RandyA
geresti Posted July 3, 2008 #3 Posted July 3, 2008 My bike did something similar and it was my front tire which was stock. When I leaned the bike it would moan sort of and everyone thought it was the rear tire but when I changed the front tire first it stopped. Bob http://smileys.smileycentral.com/cat/5/5_2_110.gif http://www.smileycentral.com/sig.jsp?pc=ZSzeb097&pp=ZNxmk393BBUS
WilCruise Posted July 3, 2008 #4 Posted July 3, 2008 I had the same thing with the Dunlops. Swapped to Avons this spring and it's gone.
Cdnlouie Posted July 4, 2008 Author #5 Posted July 4, 2008 Yes, "moan" is a good description of the sound. I was trying to think how to describe it and that does it well. Everything is in good shape on my bike including a fresh driveshaft lube so I am thinking it is tire sound. I am due to change out my front one right away so that will knock that one out of the equation. It may take a while to do the rear one yet, but depending on my level of patience I may change it out sooner than later. Good thoughts,
Semi-retired Posted July 18, 2008 #6 Posted July 18, 2008 I hope everyone's right about the tires being the primary offender on the lean/moan syndrome. My 03's been doing it since I bought it with 10,000 miles on it last June. It moans AND groans when leaning off center in BOTH directions. (I also have additional noise happening in the 80-90 KPH speed range, but I'm assuming that's a "Venture thing". Planning on installing two new Venoms in a couple of weeks, so that'll validate the "tire factor".....one way or another. Also planning on dropping front to 130 size, and dropping the triple clamps at the same time. Hoping all three of these moves will create a whole new ride! Yes, "moan" is a good description of the sound. I was trying to think how to describe it and that does it well. Everything is in good shape on my bike including a fresh driveshaft lube so I am thinking it is tire sound. I am due to change out my front one right away so that will knock that one out of the equation. It may take a while to do the rear one yet, but depending on my level of patience I may change it out sooner than later. Good thoughts,
PBJ Posted July 18, 2008 #7 Posted July 18, 2008 My 85 has Dunlop Elite III's on them and it was one of the first things i noitce about the bike. Leaned over at speed the rear was giving me noise too, The tire still has plenty of center thread but it is a bit flattened out. When i ride it into the thicker side thread then i get noise. My first assumption was it has to be the touring tire componds for such a heavy bike. My Honda Sabre 1100 is about 560lbs. and I never have gotten noise out of those tires whether I was running Dunlops, Continentals or Kendra's.
SilvrT Posted July 18, 2008 #8 Posted July 18, 2008 Ditto on the tires! Mine whined on right hand curves at higher speed (ie. 40-50 mph & up) ... Had a reasonably good Venom X ... got a nail in it so changed it to new one...same kind... whine gone... got about 8K on it now... whine is coming back.
Rocket Posted July 18, 2008 #9 Posted July 18, 2008 Ditto on the tires! Mine whined on right hand curves at higher speed (ie. 40-50 mph & up) ... Had a reasonably good Venom X ... got a nail in it so changed it to new one...same kind... whine gone... got about 8K on it now... whine is coming back. Maybe It's telling you, it's too dry & hot, not moist & cool (as per normal)...........:rotf:
SilvrT Posted July 18, 2008 #10 Posted July 18, 2008 Maybe It's telling you, it's too dry & hot, not moist & cool (as per normal)...........:rotf: Yup... that's gotta be it... c'mon RAIN... I need more WET WEATHER riding time!! Actually tho, this summer is turning out great! I'm luvvin it!
