Guest Katydid
Does anyone know of a source for generic handlebar mounted switches for accessories? Thanks, Dave
Is this what you mean , or is this what you are looking for in an accessory switch??
If so, check JC Whitney..
Guest Katydid
YES thats what I'm looking for...I didnt see these on the JCW website, but I'll go look again. Thanks, Eck
Guest Katydid
Thats exactly what I needed...thanx, Scott(s) for the links. :cool10: Dave
Guest Katydid
Bigbikeparts website is under construction
I have one from JCW too. Mounted it over the clutch resvoir. No power going thru the switches thou. I have it wire stricly as a grounding switch for the relay running the low beam headlight, spots , and bullet gauge lights
Larry
